Axis movement problem [SOLVED]
14 Mar 2012 12:59 - 14 Mar 2012 21:33 #18597
by labmaster
Axis movement problem [SOLVED] was created by labmaster
I don't know if this is a configuration issue or this thread should be in another area in the forum.
Anyway, my problem is that axis movement starts before another axis has reach its destination. This means for example that there will be a bigger radius in all corners during pocketing and other operations similar to pocketing on the inside of an area.
Let's us use the following as an example
G0 X0Y50
G1 Z-1.0
G1 F800 Y200
G1 F800 X400 // X-axis stars before Y-axis has reach 200
G1 F800 Y0 // Y-axis stars before X-axis has reach 400
G1 F800 X0 X-axis stars before Y-axis has reach 0
G1 F800 Y50 Y-axis stars before X-axis has reach 0
G1 Z30.0 Z-axis stars before Y-axis has reach 50
Is there any one out there who can help me solve this issue?
G0 X0Y50
G1 Z-1.0
G1 F800 Y200
Last edit: 14 Mar 2012 21:33 by labmaster.
14 Mar 2012 13:09 #18598
by BigJohnT
Replied by BigJohnT on topic Re:Axis movement problem
What trajectory control G code are you using?
linuxcnc.org/docview/2.5/html/common/User_Concepts.html
14 Mar 2012 13:28 #18599
by labmaster
Replied by labmaster on topic Re:Axis movement problem
Tank's for your quick reply, this helped me a lot.
