Help with my plasma config
- vladilinsky
03 May 2012 16:09 - 03 May 2012 16:10 #19767
by vladilinsky
Help with my plasma config was created by vladilinsky
Hello,
What I have done is use pncconf to generate a basic config that with it I can use the arrow keys on my keyboard to drive around the plasma head.
Then I took the configs from gnipsel.com/shop/plasma/plasma.xhtml and attempted to modify them by comparing them to what pncconf made.
The important part (i think) of the error when I try to start linux cnc is
Debug file information:
plasma.hal:270: Pin 'thc.torch-on' does not exist
2165
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
The relevant area around line 270 of my plasma.hal is
# spindle on starts the arc
net spindle-on motion.spindle-on => parport.0.pin-16-out
net spindle-on thc.torch-on
# starts the motion when the plasma arc has transfered to the work
net start-motion-input thc.arc-ok <= motion.digital-in-00 <= parport.0.pin-15-in
What file should I put the thc.torch-on pin in, and how should I parse it?
2165
Last edit: 03 May 2012 16:10 by vladilinsky.
03 May 2012 16:14 #19768
by BigJohnT
Replied by BigJohnT on topic Re:Help with my plasma config
You missed loading the thc component... look for loadrt thc and addf thc in my plasma.hal file.
- vladilinsky
03 May 2012 16:44 #19771
by vladilinsky
Replied by vladilinsky on topic Re:Help with my plasma config
Thanks.
I am trying really hard to be self sufficient in this endever but it is definitely stretching the limits of my knowledge.
I am now stuck at this error
shop@shop-desktop:~$ emc
EMC2 - 2.5.0-pre2-626-g402b6cd
Machine configuration directory is '/home/shop/emc2/configs/plasma'
Machine configuration file is 'plasma.ini'
Starting EMC2...
emc/iotask/ioControl.cc 751: can't load tool table.
Error: no pyvcp element in file!
Shutting down and cleaning up EMC2...
Cleanup done
In my ini file I am calling plasma.xml, and the file exists.
# Highest value that will be allowed for feed override, 1.0 = 100%
MAX_FEED_OVERRIDE = 2
MAX_LINEAR_VELOCITY = 1
DEFAULT_LINEAR_VELOCITY = .025
PROGRAM_PREFIX = /home/shop/emc2/nc_files
INTRO_TIME = 5
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
EDITOR = gedit
PYVCP = plasma.xml
[/i]
and the tool table loading part
# tool table file
TOOL_TABLE = tool.tbl
But runing find / tool.tbl showed no results. Do I even need this?
Starting EMC2...
Cleanup done
INTRO_TIME = 5
EDITOR = gedit
PYVCP = plasma.xml
[/i]
# tool table file
03 May 2012 16:49 #19772
by BigJohnT
You need a text file called tool.tbl in the config directory.
This link
is a sample tool table. Just copy it to start with or and I'm not sure you might just comment out the tool table line and see if it runs. No need for a tool table for a plasma unless your using tool diameter offsets instead of having the cam software create the offset path.
- vladilinsky
03 May 2012 16:50 #19773
by vladilinsky
the plasma.xml file is unchanged from
<pre>
<pyvcp>
<hbox>
<checkbutton>
<text>"THC Enable"</text>
<halpin>"thc-enable"</halpin>
</checkbutton>
</hbox>
<labelframe text="THC Settings">
<hbox>
<vbox>
<label>
<text>"Vel Tolerance "</text>
<font>("Helvetica",10)</font>
</label>
<label>
<text>"Volts Setting "</text>
</label>
<label>
<text>"Volts Tolerance"</text>
</label>
</vbox>
<vbox>
<spinbox>
<width>"5"</width>
<halpin>"vel-tol"</halpin>
<min_>.01</min_>
<max_>1</max_>
<resolution>0.01</resolution>
<initval>0.2</initval>
<format>"1.2f"</format>
<font>("Arial",10)</font>
</spinbox>
<spinbox>
<width>"5"</width>
<halpin>"volts-requested"</halpin>
<min_>0</min_>
<max_>200</max_>
<resolution>1</resolution>
<format>"1.0f"</format>
<initval>1</initval>
</spinbox>
<spinbox>
<width>"5"</width>
<halpin>"volts-tolerance"</halpin>
<resolution>0.1</resolution>
<min_>0</min_>
<max_>10</max_>
</spinbox>
</vbox>
</hbox>
</labelframe>
<labelframe text="Arc Volts Status">
<hbox>
<vbox>
<label>
<text>"Under"</text>
</label>
<rectled>
<halpin>"volts-under"</halpin>
<height>"20"</height>
<width>"40"</width>
<on_color>"green"</on_color>
<off_color>"red"</off_color>
</rectled>
</vbox>
<vbox>
<label>
<text>"OK"</text>
</label>
<rectled>
<halpin>"volts-ok"</halpin>
<width>"40"</width>
</rectled>
</vbox>
<vbox>
<label>
<text>"Over"</text>
</label>
<rectled>
<halpin>"volts-high"</halpin>
<width>"40"</width>
</rectled>
</vbox>
</hbox>
</labelframe>
<labelframe text="Status">
<hbox>
<vbox>
<label>
<text>"Velocity"</text>
</label>
<rectled>
<halpin>"vel-status"</halpin>
<width>"40"</width>
</rectled>
</vbox>
<vbox>
<label>
<text>"Arc"</text>
</label>
<rectled>
<halpin>"arc-ok"</halpin>
<width>"40"</width>
</rectled>
</vbox>
<vbox>
<label>
<text>"Offset"</text>
</label>
<number>
<halpin>"offset"</halpin>
<format>"+4.4f"</format>
</number>
</vbox>
</hbox>
</labelframe>
<label text="Actual Volts"/>
<meter>
<halpin>"actual-volts"</halpin>
<text>"Torch"</text>
<subtext>"Volts"</subtext>
<size>150</size>
<min_>0</min_>
<max_>200</max_>
<majorscale>25</majorscale>
<minorscale>5</minorscale>
</meter>
<labelframe text="MDI Commands">
<button>
<halpin>"rapid-to-home"</halpin>
<text>"Rapid to Home"</text>
<font>('Helvetica',10)</font>
</button>
</labelframe>
</pyvcp>
</pre>
1,1 Top
<pre>
<pyvcp>
<hbox>
<checkbutton>
</checkbutton>
</hbox>
<hbox>
<vbox>
<label>
</label>
<label>
</label>
<label>
</label>
</vbox>
<vbox>
<spinbox>
<width>"5"</width>
<min_>.01</min_>
<max_>1</max_>
</spinbox>
<spinbox>
<width>"5"</width>
<min_>0</min_>
<max_>200</max_>
</spinbox>
<spinbox>
<width>"5"</width>
<min_>0</min_>
<max_>10</max_>
</spinbox>
</vbox>
</hbox>
</labelframe>
<hbox>
<vbox>
<label>
</label>
<rectled>
<width>"40"</width>
</rectled>
</vbox>
<vbox>
<label>
<text>"OK"</text>
</label>
<rectled>
<width>"40"</width>
</rectled>
</vbox>
<vbox>
<label>
<text>"Over"</text>
</label>
<rectled>
<width>"40"</width>
</rectled>
</vbox>
</hbox>
</labelframe>
<hbox>
<vbox>
<label>
</label>
<rectled>
<width>"40"</width>
</rectled>
</vbox>
<vbox>
<label>
<text>"Arc"</text>
</label>
<rectled>
<width>"40"</width>
</rectled>
</vbox>
<vbox>
<label>
</label>
<number>
</number>
</vbox>
</hbox>
</labelframe>
<meter>
<size>150</size>
<min_>0</min_>
<max_>200</max_>
</meter>
<button>
</button>
</labelframe>
</pyvcp>
</pre>
1,1 Top
03 May 2012 16:52 #19774
by BigJohnT
I just tested and no complaints if you just delete the tool table line...
- vladilinsky
03 May 2012 16:57 #19775
by vladilinsky
did you just remove it from the .ini file? I have commented out tool_table and the Tool_change_... and it still complains
03 May 2012 17:01 - 03 May 2012 17:02 #19776
by BigJohnT
Just another note anything in the postgui.hal file you copied must be in the postgui.hal file. What happens is after the GUI loads then the postgui.hal file is loaded and the pyvcp pins are now available to be used.
linuxcnc.org/docview/html/config/ini_con...id_sub_hal_section_a
Last edit: 03 May 2012 17:02 by BigJohnT.
03 May 2012 17:03 #19777
by BigJohnT
I just commented out the tool table.
- vladilinsky
03 May 2012 17:05 #19778
by vladilinsky
I found some lines in the plasma.hal that needed to be commented out to make the tool.tbl error go away, now I am just working on the pyvcp issue.
Time to create page: 1.085 seconds
