Need Help with setup
31 May 2012 20:50 - 31 May 2012 21:16 #20538 by ricky_a
Need Help with setup was created by ricky_a
Hi I am beginner in cnc.
I'm having trouble getting my machine to run. I am running with linix cnc, it can only be run manually during stepconf Wizard. When I start linux cnc and running, I can see the LEDs light up to the axis of my brekout board, but the drivers are turned off. I run with these parts PM542 Microstepping Driver, ZP5A-INT 5 axis breakout board, SPS407 Power supplie 42V and SY60STH88-3008B Nema 23 stepper motor. The machine is for plasma cutting
Last edit: 31 May 2012 21:16 by ricky_a.
31 May 2012 21:11 #20540 by BigJohnT
Replied by BigJohnT on topic Re:Need Help with setup
I assume your using the Axis GUI... Have you read the few pages on it?
linuxcnc.org/docview/html/gui/axis.html
01 Jun 2012 12:24 #20558 by andypugh
Replied by andypugh on topic Re:Need Help with setup
Starting with very basic, are you out of E-stop and turned on? (F1 then F2)
04 Jun 2012 08:03 #20631 by ricky_a
Replied by ricky_a on topic Re:Need Help with setup
yes emergency stop is deactivated.
And it's on.
I can press play and it starts and run on PC. but the drivers will not start.
04 Jun 2012 09:56 #20633 by ArcEye
Replied by ArcEye on topic Re:Need Help with setup
Hi
This is a manual for your drivers in case you don't have one, so you can check they are wired correctly.
Particularly check what you have done with the Enable connections
www.zappautomation.co.uk/pdf/manuals/PM542%20Manual.pdf
You will need to post your .ini and .hal files for us to be able to advise further.
04 Jun 2012 10:11 #20635 by cncbasher
Replied by cncbasher on topic Re:Need Help with setup
disconnect the enable wires from the stepper drivers if you have them connected ,
due to the way this board buffers the signals you may also need to set the parallell port pin 1 to be set in your hal file as an amplifier enable , it may also need to be inverted.
hopfully the first solution will work
Dave
04 Jun 2012 11:03 #20637 by ricky_a
how can i find my hal file
04 Jun 2012 11:17 - 04 Jun 2012 11:20 #20638 by ArcEye
Hi
/home/your-user-name/emc2(or linuxcnc is using 2.5)/configs/machine-name.hal and machine-name.ini
Last edit: 04 Jun 2012 11:20 by ArcEye.
04 Jun 2012 11:18 #20639 by BigJohnT
Assuming your using 2.5 LinuxCNC then the configuration files are located in linuxcnc/configs/name of your config. If you zip them up into one file it is easier to attach them to a message.
04 Jun 2012 11:26 - 04 Jun 2012 11:29 #20641 by cncbasher
if the green led is not lit on your stepper drivers then the drives are in a disabled state ... removing the connection to the ENA- on the stepper driver should give you enabled
so long as of course you have your stepper power connected to VCC & GND
once you have the green led lit , trying to turn the stepper shaft now it should feel solid and unable to move in direction
Last edit: 04 Jun 2012 11:29 by cncbasher.
Time to create page: 0.442 seconds
