Homing stops immediately
01 Jun 2012 04:28 #20546
by maxvdh
Homing stops immediately was created by maxvdh
I'm now trying to get homing set up and get my servo PID loops tuned. For some reason, when I click "home axis" for X, Y, or Z in AXIS, that axis quickly jumps in the appropriate direction and then stops and displays the symbol next to the positoin readout that it is homed. It does not travel all the way to the home switch and it has not tripped an estop or anything. I have verified that the home switches work as I expect and axis.0/1/2.home-sw-in become true when the machine runs over the home switch. If I keep pressing home until it actually passes over the home switch, it will ignore the switch and continue the same behavior until it hits the limit switch. Why doesn't it properly complete the homing sequence? HAL and INI files attached.
01 Jun 2012 07:48 - 01 Jun 2012 08:08 #20551
by ArcEye
Replied by ArcEye on topic Re:Homing stops immediately
Hi
Looks like you are missing several things from your .ini file for each axis.
eg
HOME_OFFSET = 0.000
HOME_SEARCH_VEL = 3.5
HOME_LATCH_VEL = 1.5
HOME_SEQUENCE = 0
or similar
I think that if you don't define SEARCH and LATCH VEL they default to 0 which will home immediately
You need to read linuxcnc.org/docs/2.5/html/config/ini_homing.html
PS Don't use the values above if you are using imperial, I am using metric!!
PPS The axis should not move at all but that may be down to your unfinished tuning
eg
HOME_OFFSET = 0.000
HOME_SEQUENCE = 0
or similar
Last edit: 01 Jun 2012 08:08 by ArcEye.
01 Jun 2012 16:55 #20574
by maxvdh
Replied by maxvdh on topic Re:Homing stops immediately
Thanks, that looks like the right information.
01 Jun 2012 17:02 #20576
by BigJohnT
Replied by BigJohnT on topic Re:Homing stops immediately
The one important thing that I have failed to put in that section is where to connect the home switch input to in HAL... darn manual guys dropped the ball.
axis.N.home-sw-in IN BIT Should be driven TRUE if the home switch for this joint is closed
Time to create page: 0.408 seconds
