Servo vibration
27 Jun 2012 12:22 #21377
by Linux-Hus
Servo vibration was created by Linux-Hus
Hello, we have one problem with the servo vibration.
The input-scale in the ini file is 250, The impulse to pc is comming from Heidenhain ROD424.
1rev = 250 counts and 0,2rev/mm
50counts / 1mm
this is axis0 exemple in the inifile:
# First axis
[AXIS_0]
TYPE = LINEAR
UNITS = mm
HOME = 0.000
MAX_VELOCITY = 1.0
MAX_ACCELERATION = 4.0
BACKLASH = 0.000
#INPUT_SCALE = 81920
INPUT_SCALE = 250
OUTPUT_SCALE = 1
OUTPUT_OFFSET = 0
MIN_LIMIT = -100.0
MAX_LIMIT = 100.0
FERROR = 100.000
#MIN_FERROR = 0.002
HOME_OFFSET = 0.10
HOME_SEARCH_VEL = 0.10
HOME_LATCH_VEL = -0.01
HOME_USE_INDEX = YES
HOME_IGNORE_LIMITS = YES
MAX_OUTPUT = 10.0
# PID tuning params
DEADBAND = 0.000015
P = 100.0
I = 0.000
D = 0.000
FF0 = 0.000
FF1 = 0.000
FF2 = 0.0
BIAS = 0.000
50counts / 1mm
# First axis
[AXIS_0]
TYPE = LINEAR
UNITS = mm
HOME = 0.000
MAX_VELOCITY = 1.0
BACKLASH = 0.000
INPUT_SCALE = 250
OUTPUT_SCALE = 1
OUTPUT_OFFSET = 0
MIN_LIMIT = -100.0
MAX_LIMIT = 100.0
FERROR = 100.000
#MIN_FERROR = 0.002
HOME_OFFSET = 0.10
MAX_OUTPUT = 10.0
# PID tuning params
DEADBAND = 0.000015
P = 100.0
I = 0.000
D = 0.000
FF0 = 0.000
FF1 = 0.000
FF2 = 0.0
BIAS = 0.000
27 Jun 2012 12:31 #21380
by BigJohnT
Replied by BigJohnT on topic Re:Servo vibration
This does look like it goes in the Servo Tuning as I see you have not done any... but I can't move it for some strange reason.
27 Jun 2012 14:06 #21383
by Linux-Hus
Replied by Linux-Hus on topic Re:Servo vibration
you have an example of what should be there in the PID and FF
27 Jun 2012 15:14 #21386
Replied by PCW on topic Re:Servo vibration
There are no fixed PID numbers as they must always be adjusted for each system
this is called "tuning"
How tuning is done depends on your drive type (the motor drive) that is whether it is a:
1. Velocity mode drive (drive with local velocity feedback loop often with tachometer)
2. Torque mode drive (current mode)
3. Simple HBridge (voltage mode)
If you can provide this information it would be easier to help
27 Jun 2012 17:21 #21397
by Linux-Hus
We have +/-10V and the impulse is comming from the servomotor-encoder
27 Jun 2012 18:15 #21400
OK so that means a velocity or torque mode drive
Do you have any idea which it is?
Is there a tachometer on the motor?
Do you have the motor drive part number?
Does the encoder signal go to the drive?
27 Jun 2012 19:26 - 27 Jun 2012 19:40 #21408
by Linux-Hus
we send +/- 10V to the servomotor and the encoder singnal is comming back from Heidenhain ROD424.
The Heidenhain ROD424 is on the servomotor and from this comming the singnal to pc.
The Servo have nothing tachometer.
The +/-10V going to one Magnetventil and the magnetventil controls the hydraulicmotor.
The Axis drive Hydraulic and the hydraulicmotor have the encoder and this encode send the singnal to pc.
Last edit: 27 Jun 2012 19:40 by Linux-Hus.
27 Jun 2012 21:50 #21416
OK well on the basis of not understanding your hardware at all I would try this
start with a low P term (say 1) and increase it slowly till you get oscillation (vibration)
Then start adding D term until the vibrations cease (to much will cause vibrations to start again)
Can you provide a HALScope plot of the vibrations?
28 Jun 2012 01:01 #21418
by VNR
Replied by VNR on topic Re:Servo vibration
I think if the encoder have 250 pulses/rev and 1 rev is 5mm then INPUT_SCALE should be 50 not 250 (250 is equal to 1 rev or 5 mm, 50 is equal to 1/5 rev or 1 mm).
Also DEADBAND should be equal to 1, 1.5, 2 o 3 encoder counts (i mean 1/50, 1.5/50, 2/50 or 3/50 mm).
28 Jun 2012 06:12 #21421
by Linux-Hus
OK, Thanks.
I'm back on freday again.
Steffen
Steffen
Time to create page: 0.105 seconds
