Configuration Problems for The Beast
05 Jul 2012 03:49 #21602 by BruceLayne
cmorley wrote:
If you are trying to use PNCconf from the live CD for the 5i25 you are going to get errors.
You need to get linuxcnc from the buildbot - it has bug fixes.
buildbot.linuxcnc.org/
You can hand edit configs for the 5i25 from the live cd but as you have found its a real steep hill.
I just tried the buildbot and it seems to be down right now...
I wish I could buy you guys a beverage of your choice for such useful information! Thank you!
I'll keep trying the buildbot, and hopefully get the latest and greatest from there.
I guess there's a good reason that the download page (near the top of the column to the left of this page) doesn't have the most recent version?
I need to reread the parts about software updates. Update manager kept wanting me to update Ubuntu, but I remembered reading that I shouldn't, because it'd break LinuxCNC? I have three different distros now, and I can't keep their recommended update policies straight. My notebook PC is running PCLinuxOS, and they expect updates at most every two weeks or it can get out of sync with no update path, requiring reinstallation, and those weekly updates seem to break as much as they fix. Ubuntu LTS is starting to look pretty good. Maybe Kubuntu, as I prefer the KDE GUI.
05 Jul 2012 11:13 #21605 by BigJohnT
The download page has the LiveCD 2.5.0 version of LinuxCNC. As bug fixes come in then a new version will be released for updating via the Synaptic Package Manager. The LiveCD takes considerable time to prepare along with some black magic (I think) so only the major releases get put on the LiveCD.
While we are on that subject open up System > Adminstration > Synaptic Package Manager go to Settings > Repositories and on the Updates tab at the bottom select Never for show new distribution releases:. Now you won't have to worry about updating the release.
05 Jul 2012 15:15 #21611 by PCW
Peter is the 7i64 on serial # 1 because the 7i77 isn't powered up?
No, it should be port 2 if on the first 7I77s expansion port
The first 7I77s expansion port is always port 2, that is sserial devices
currently have static port numbers
05 Jul 2012 16:22 #21618 by andypugh
But we start counting at zero.
05 Jul 2012 16:53 #21621 by PCW
sure, on 7I77:
0 = field I/O
1 = analog out/enables
2 = expansion port
05 Jul 2012 17:12 #21624 by andypugh
PCW wrote:
sure, on 7I77:
0 = field I/O
2 = expansion port
Ah, OK. That seems to suggest that only the analogue outs was being detected then, as only sserial.1 was showing.
05 Jul 2012 17:15 #21625 by PCW
Yes, thats exactly what you would expect with no 7I77 field power
(so no chan 0) and no 7I64 (so no chan 2)
05 Jul 2012 17:31 - 05 Jul 2012 17:34 #21626 by BruceLayne
I had no +24V to the 7i77, just the +5V that was parasitically supplied from the 5i25, and the 7i64 wasn't connected at all. I may have only tried to configure the bare necessities required by PNCconf to avoid errors - just the servo encoders and PWM.
I'll try PNCconf again, with the field power supplied to the 7i77, the 5V logic power and 24V field power supplied to the 7i64, and the RS422 connecting the 7i77 and the 7i64.
I was trying to configure the system and then wire it, but there are several hints that it should be wired and THEN configured. I figured that it's easier to change the configuration than the wiring if there is a conflict or problem, and I expected problems as I basically made up the details as I went. I didn't understand all of the various constraints and interactions between MESA hardware and LinuxCNC, so I was trying to figure it out by playing with PNCconf. That seems like a bad strategy. I'll revert to good engineering practices, understand the entire system as best I can, plan everything, wire the important parts, and then try to configure it. I'll get all of the MESA hardware connected and fully powered before trying to use PNCconf to configure it.
And as always...
THANK YOU VERY MUCH FOR YOUR SELFLESS EFFORTS ON MY BEHALF. I'd never be able to figure this stuff out on my own.
Last edit: 05 Jul 2012 17:34 by BruceLayne.
05 Jul 2012 18:08 #21628 by andypugh
Probably the best plan, but be aware that Pncconf will probably only get you 95% of the way there, and some manual HAL editing is likely to be required.
05 Jul 2012 18:35 #21629 by BruceLayne
I've been trying buildbot last night and all day today. Any idea when it'll be back up?
Can I do a fresh reinstallation of everything (Ubuntu and LinuxCNC) and then use Synaptic or apt to upgrade to the latest LinuxCNC?
Time to create page: 0.101 seconds
