Setup for plasma cutting need help
16 Jul 2012 15:01 #22001
by BigJohnT
Replied by BigJohnT on topic Re:Setup for plasma cutting need help
Do you have the hardware required by that configuration?
16 Jul 2012 15:41 #22005
by ricky_a
Replied by ricky_a on topic Re:Setup for plasma cutting need help
I do not understand what you mean
16 Jul 2012 15:47 #22006
Replied by andypugh on topic Re:Setup for plasma cutting need help
ricky_a wrote:
OK, so you are wanting to add extra controls to the right of the screen.
There are two ways to add extra controls to the Axis user interface, the slightly old-fashioned PvVCP and the new-fangled GladeVCP.
If you look at the bottom of that Wiki link you pasted you will find links to a set of files. One version using GladeVCP and one using PyVCP.
You can get close to that config by adding the XML file from that page: (custom_pyvcp.xml) to the configuration folder for your machine, then add:
PYVCP = custom_pyvcp.xml in the [DISPLAY] section of the INI file.
Note that it won't actually _do_ anything, because all the buttons and controls need to be connected to functions and hardware in HAL, and the configuration in the Wiki page uses Mesa interface cards which I don't think you have.
So, once you have the extra buttons displayed, you can look in Machine->show hal config to see all the pin names associated with the new buttons, and edit the postgui.hal file to make the required connections.
This is what i have
16 Jul 2012 17:12 #22014
by ricky_a
OK that make sense.
So how do we make our configuration right for the plasma?
How do we set the start and stop point for the plasma on the drawing that we made?
And we need to get the THC working...
16 Jul 2012 18:35 #22018
by BigJohnT
ricky_a wrote:
Do you have a plasma machine now?
If so what machine do you have?
16 Jul 2012 18:46 #22020
by ricky_a
yes it is a Migatronic PDX 70 plasma cutter it is a Danish machine but it is old
16 Jul 2012 18:49 #22022
by ricky_a
16 Jul 2012 18:53 #22023
by BigJohnT
Does the plasma cutter have a torch on input?
Do you have a THC on the plasma cutter? If so what inputs does it use?
16 Jul 2012 18:55 #22024
by ricky_a
the plasma cutter is connected with the linuxcnc we can turn it on and off in the program manual, but we don't now how to program it with the drawing so it starts and stops by it self
16 Jul 2012 18:57 #22025
by BigJohnT
How do you turn it on and off in manual?
Time to create page: 0.094 seconds
