W axis with gantry kins hal/ini configuration
- guymalpass
08 Dec 2015 21:44 #66643
by guymalpass
Replied by guymalpass on topic W axis with gantry kins hal/ini configuration
Thanks for that, I'll have a go with JA9 tomorrow and report back. I think a working gentrivkins is preferable to gantrykins, ignoring soft limits scares the hell out of me!
- guymalpass
08 Dec 2015 22:24 #66646
by guymalpass
Could you also please tell me what KINSTYPE=BOTH does? I can't seem to find anything out about it.
08 Dec 2015 22:34 #66647
There is a hint here:
github.com/jepler/linuxcnc-mirror/blob/m...otion/kinematics.txt
Though not its use as a module parameter.
Replied by andypugh on topic W axis with gantry kins hal/ini configuration
08 Dec 2015 23:12 #66648
by dgarrett
Replied by dgarrett on topic W axis with gantry kins hal/ini configuration
The code is basically identical for gantrykins and gentrivkins.
I don't know the reason for both or the naming history.
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...s/heads/joints_axes9
man page:
buildbot.linuxcnc.org/doc/scratch/v2.8.0...man/man9/kins.9.html
In joints_axes9, gentrivkins has a (new) module parameter
kinstype for testing. It makes it possible to test a simple
kinematics module as if it were a more complex
(non-identiry) kinematics type.
I used it in the example to illustrate switching between
joint and teleop mode so that you can see the pos-cmds for
both modes in the included halshow gui.
Some guis (axis for example) suppress joint/world switching
for identity kins. In the g.tgz example, remove the text
'kinstype=BOTH' to see the gui behavior for kinematics that
are strictly identity.
man page:
09 Dec 2015 00:46 #66651
Gentrivkins is intended as a kinematics that allows free mapping of joints to axes but declares kinematics_identity and so does not expose the complications of joint/world mode.
I _think_ it still allows homing in joint mode.
- guymalpass
09 Dec 2015 13:57 - 09 Dec 2015 14:00 #66683
by guymalpass
I've built JA9, configured with gentrivkins and everything is working perfectly! Gantry auto-squaring, obeyed soft limits and automatic teleop are exactly what I was after, thanks Todd, Dewey and Andy for your help with this. I expect the problem remains with gantrykins and non JA builds but I much prefer this setup.
Last edit: 09 Dec 2015 14:00 by guymalpass.
10 Dec 2015 18:41 #66747
by mozmck
Replied by mozmck on topic W axis with gantry kins hal/ini configuration
Would you mind sharing your config? I need to set up a gantry with auto-squaring myself.
- blacksmith
11 Dec 2015 16:09 #66829
by blacksmith
Does the author of the Joints branch have any sample configs?
LCNC is like the punishment of Tantalus.
Replied by blacksmith on topic W axis with gantry kins hal/ini configuration
11 Dec 2015 16:14 - 11 Dec 2015 16:14 #66830
If you install the branch, then most of the configs work I believe.
Details: sourceforge.net/p/emc/mailman/message/34685502/
Last edit: 11 Dec 2015 16:14 by andypugh.
- guymalpass
11 Dec 2015 16:16 #66831
by guymalpass
I can post my config files later tonight for you
Time to create page: 0.214 seconds
