TOOL_CHANGE_QUILL_UP = 1 with absolute encoders
17 Oct 2016 12:18 - 17 Oct 2016 12:18 #81717
by terkaa
TOOL_CHANGE_QUILL_UP = 1 with absolute encoders was created by terkaa
I was trying to use TOOL_CHANGE_QUILL_UP = 1 option. But I get an error about position that would go over limits. I have HOME_ABSOLUTE_ENCODER = 2 set in INI. I tried setting HOME = -80 but behaviour was same. Limits are: MAX = -70 MIN=-420. Solved this by adding G0 G53 Z -80 before M6 in gcode. Version is 2.8.0 pre1
Tero
Tero
Last edit: 17 Oct 2016 12:18 by terkaa.
17 Oct 2016 22:44 #81751
Replied by andypugh on topic TOOL_CHANGE_QUILL_UP = 1 with absolute encoders
What are the axis limits set to? How close to that limit does it let you jog?
18 Oct 2016 04:07 #81759
by terkaa
Replied by terkaa on topic TOOL_CHANGE_QUILL_UP = 1 with absolute encoders
Limits are MAX = -70 MIN = -420. I can jog to -71. And TOOL_CHANGE_POSITION = -500 400 -80 and it works
Time to create page: 0.233 seconds
