how to get Mesa THC values
- echesortux
- Topic Author
25 Oct 2016 12:15 #82035
by echesortux
how to get Mesa THC values was created by echesortux
Hello I have a Mesa 5i25 + 7i76 last weekend I have hooked up the Mesa thcad I am reviewing some examples from John but I am in doubt how to calc this values for my machine. where do they get? I have an Hyperthem 65 and the THCad 10V
setp thc.scale-offset 119000
setp thc.vel-scale 0.00037866834
# this might need to be increased
setp thc.correction-vel 0.0001
someone can help me?
25 Oct 2016 20:31 #82059
by jtc
some time ago I start a tutorial how to calibrate a THCAD10 board, it isn't finished (shame on me) but I believe that is enough to understand the principles.
jtctech.pt/wiki/index.php?title=Mesa_Thcad10_calibration
download the excel file, place the values and it's almost everything done I use the frequency divided by 32 in the tchad10.
João
Replied by jtc on topic how to get Mesa THC values
João
The following user(s) said Thank You: echesortux
26 Oct 2016 06:01 #82075
by Rick G
Replied by Rick G on topic how to get Mesa THC values
There is a section on calibration for the THC in the manual...
www.mesanet.com/pdf/analog/thcadman.pdf
I then used a known voltage source such as a battery and meter to confirm the voltage in linuxcnc was correct.
You can adjust this for your machine, as I recall if set too high the Z axis will oscillate up and down during the cut by overcompensating.
Rick G
Rick G
- echesortux
- Topic Author
26 Oct 2016 16:29 #82092
by echesortux
Replied by echesortux on topic how to get Mesa THC values
26 Oct 2016 17:54 #82107
by BigJohnT
Replied by BigJohnT on topic how to get Mesa THC values
Looks correct to me.
JT
JT
- echesortux
- Topic Author
26 Oct 2016 19:51 #82113
by echesortux
Hi John, how do you get this values? I am trying to understand your plasma.hal to using with my machine.
thanks
thanks
- echesortux
- Topic Author
26 Oct 2016 20:20 #82115
by echesortux
setp thc.scale-offset 119000 = frequency 0V ?
setp thc.vel-scale 0.00037866834 = 300v/(916100Hz - 119100Hz) = 0.000376411 aprox.
setp thc.correction-vel 0.0001 =???
26 Oct 2016 20:28 #82116
by jtc
1- yes, is the measured freq at 0v
2- slope of the line, I prefer to make some measurements and calc a trend line on excel to get the slope value.
3- I use a modified THC comp, so I cant help you on this one.
- Thank you received: 5925
26 Oct 2016 22:07 #82123
Replied by tommylight on topic how to get Mesa THC values
This is by how much the value will change while correcting the height, to high and the torch will bounce like a bunny, to little and it will be to slow at going up or down, so you have to test some values there to get smooth movement. That is dependant on your setup, speed of Z axis, delay on the motor drives, etc.
07 Nov 2016 17:19 #82553
by BigJohnT
The THCAD manual tells you where to get the scale offset number, it's different for each card a bit I think.
JT
thanks
JT
Time to create page: 0.282 seconds
