Super slow velocity issues....
- nigel-tufnel
26 Mar 2017 22:17 #90318
by nigel-tufnel
Super slow velocity issues.... was created by nigel-tufnel
I am having issues with my Y-axis homing using AXIS but not my X-axis homing. The issue is that once it hits the Y-axis limit switch and starts to very slowly step out of the limit, AXIS thinks its moving but there is no actual movement. I've traced it back to the Y-axis cannot make very slow movements (below ~2in/min). The X-axis can make slower movements. Is there a variable that controls the minimum velocity or does this sound like stepper driver issues? Any suggestions on where to look would be appreciated. Thanks
- Thank you received: 5928
26 Mar 2017 23:59 #90324
Replied by tommylight on topic Super slow velocity issues....
In the ini file under the joint 1 for Y axis there are several enties for homing, below the home_search_velocity is the one you should change named home_latch_velocity.
By default it is set very low.
Is there any particular reason why Y axis will not move at lower speeds ? That is not how it should be, on all the machines i can move any axis at an extreemly low speed.
- nigel-tufnel
27 Mar 2017 00:38 #90326
by nigel-tufnel
Replied by nigel-tufnel on topic Super slow velocity issues....
Thanks for the response. I'm aware of the home_latch_velocity and I increased that as a stop-gap measure.
There is no reason that I am aware of why the Y axis should not move at lower speeds. I was hoping someone has some ideas.
I forgot to mention the following hardware in my original post:
-1.8deg stepper (x10 microstepping)
-Mesa 5i25/7i76
-Gecko 202 stepper driver
-Mesa 5i25/7i76
27 Mar 2017 08:21 #90336
Replied by rodw on topic Super slow velocity issues....
I saw a post recently from PCW where he said the Gecko 540 struggles at low velocities and your stepper is a very close relative..... try increasing the step length >5,000 was something he said...
- nigel-tufnel
16 May 2017 00:20 #93244
by nigel-tufnel
I contacted Gecko about this issue and they said it didn't sound right and to send back the drive for evaluation. I sent the drive back but they indicated "no problem found". It still exhibits this behavior.
Anyone else have any ideas on what might be causing this? (again I'm using Mesa 5i25/7i76)
RodW - can you elaborate on how/where to change the step length? I didn't see anything that look like it in my .ini file. I fear editing with the Config wizard again because I have custom tweaks to my hal and ini files I don't want to risk.
I wanted to do one last attempt at fixing before buying a new stepper drive that may or may not fix the issue.
Thanks.
Thanks.
16 May 2017 02:30 - 16 May 2017 02:36 #93248
[quote="nigel-tufnel" post=93244}
Thanks.[/quote]
In your ini file under each joint but mine will be waaay tooo short.
But review this
linuxcnc.org/docs/2.7/html/motion/tweaking-steppers.html
Thanks.[/quote]
DIRSETUP = 500
DIRHOLD = 500
STEPLEN = 1500
STEPSPACE = 1500
But review this
Last edit: 16 May 2017 02:36 by rodw.
16 May 2017 02:39 #93249
Also after reviewing the thread again and what Tommy said, review your homing setup. Here's mineSee
linuxcnc.org/docs/html/config/ini-homing.html
Running a 7i76e
HOME_OFFSET = 45
HOME_SEARCH_VEL = 0
HOME_FINAL_VEL = 100
HOME_USE_INDEX = NO
HOME_SEQUENCE = -1
Running a 7i76e
- nigel-tufnel
11 Jun 2017 19:12 #94411
by nigel-tufnel
Thanks Rod. I increased the STEPLEN value and I was able to make slow movements. However, this one axis is not as smooth as the other axes at slow speeds so it seems like there is more options for tuning. Below are my settings before increasing the STEPLEN.
DIRSETUP = 1000
DIRHOLD = 5000
STEPLEN = 500
STEPSPACE = 4500
If I increase the STEPLEN, do any of the other corresponding variables need to change accordingly? I'm using a Gecko G202. www.geckodrive.com/g202.html
Any suggested values appreciated. Thanks
DIRSETUP = 1000
DIRHOLD = 5000
STEPLEN = 500
STEPSPACE = 4500
11 Jun 2017 21:39 - 11 Jun 2017 21:39 #94418
Replied by PCW on topic Super slow velocity issues....
Unless the settings are limiting your maximum speed there's usually no reason not to use longer step timings
in addition, long direction setup and hold times have very minimal effect on performance so
DIRSETUP = 20000
DIRHOLD = 20000
STEPLEN = 5000
STEPSPACE = 5000
is a good starting point that will work with almost all drives.
Note the this will limit you to 100 KHz maximum step rate
DIRSETUP = 20000
DIRHOLD = 20000
STEPLEN = 5000
STEPSPACE = 5000
Last edit: 11 Jun 2017 21:39 by PCW.
Time to create page: 0.181 seconds
