proximity switch encoder help
- blazini36
- Thank you received: 167
27 Aug 2017 04:31 #98054
by blazini36
Replied by blazini36 on topic proximity switch encoder help
I had a small 30t gear laying around. I bored it out and pressed it on the shaft.
I setp hm2_7i76e.0.encoder.00.counter-mode 1. not sure what that does but it appears to use only one channel of the encoder, so I'm only using 1 proximity switch. I set the encoder scale to 30 until I grab my optical tach from work I don't know if speed is accurate but it's smooth on the pyvcp widget. Counts look good too from HAL show. So I suppose that if I want higher res I'll have to use a higher tooth gear.
any thoughts?
any thoughts?
- Thank you received: 4646
30 Aug 2017 14:31 #98216
Replied by andypugh on topic proximity switch encoder help
30T is probably fine, but you would need to add an index for threading.
Time to create page: 0.098 seconds
