xhc-hb04 error
02 Sep 2017 09:55 - 02 Sep 2017 10:21 #98367
by billykid
xhc-hb04 error was created by billykid
hello
after settling an existing and working configuration and adding the necessary I found this error:
CANNOT FIND FILE FOR: monitor_xhc-hb04.tcl
I attach if it was to serve the beginning of the messages
Mauro
edit: simulator work properly
Mauro
Last edit: 02 Sep 2017 10:21 by billykid.
02 Sep 2017 10:52 - 02 Sep 2017 10:52 #98368
Replied by rodw on topic xhc-hb04 error
It looks like these lines hold the key.
So what it looks like to me is that the file
/usr/share/linuxcnc/hallib/xhc-hb04.tcl
is looking for:
edit /usr/share/linuxcnc/hallib/xhc-hb04.tcl to see if you get any clues where the missing file should be.
So if you can find that file, you can either put it where its expected to be or edit the filename and path in the first file so it can find it.
Sorry, but I've never used your hardware. This is just basic troubleshooting.
Found file(lib): /usr/share/linuxcnc/hallib/xhc-hb04.tcl
CANNOT FIND FILE FOR:monitor_xhc-hb04.tcl
is looking for:
Last edit: 02 Sep 2017 10:52 by rodw.
02 Sep 2017 11:04 #98369
by billykid
Replied by billykid on topic xhc-hb04 error
thanks Rod
but it just does not seem to have that file ...
I will control better
02 Sep 2017 13:15 #98370
by dgarrett
The reported name monitor-xhc-hbo4.tcl is incorrect
(there is no .tcl in the correct name.)
and the item appears in the [APPLICATIONS] section
not the [HAL] section
From the README in the sim config directory:
Ref:
github.com/LinuxCNC/linuxcnc/blob/2.7/co...axis/xhc-hb04/README
(It is easier to help if you post relevant config files especially your ini file)
Replied by dgarrett on topic xhc-hb04 error
[APPLICATIONS]
APP = xhc-hb04-accels
APP = monitor-xhc-hb04
Ref:
The following user(s) said Thank You: billykid
02 Sep 2017 13:34 - 02 Sep 2017 13:43 #98372
by billykid
Thank you!
it was already well in [APP], but it was also repeated in the [HAL] section
it was enough to delete that.
I had seen here: wiki.linuxcnc.org/cgi-bin/wiki.pl?Using_...Wireless_MPG_Pendant
[HAL]
<existing entries here>
HALFILE=xhc-hb04.tcl
HALFILE=monitor_xhc-hb04.tcl
HALUI = halui
[HAL]
HALUI = halui
Last edit: 02 Sep 2017 13:43 by billykid.
02 Sep 2017 15:15 #98377
by dgarrett
That portion of the wiki entry is clearly wrong.
No one takes responsibility for reviewing or maintaining wiki entries.
However, numerous contributors attempt to update and maintain
documentation within the LinuxCNC project.
Time to create page: 0.341 seconds
