Stepper Motors work in stepconf but not in in Linux Cnc
08 Oct 2018 19:38 - 08 Oct 2018 19:46 #118555
by wl
Stepper Motors work in stepconf but not in in Linux Cnc was created by wl
Hi, is there anything you can recommend to look at to solve this issue?
thank you
Wolfgang
thank you
Wolfgang
Last edit: 08 Oct 2018 19:46 by wl.
- Thank you received: 1370
08 Oct 2018 19:49 #118557
Replied by Todd Zuercher on topic Stepper Motors work in stepconf but not in in Linux Cnc
One of the most common problems is that you tried to configure a "drive enable" signal to the drive. Most stepper drives have drive disable inputs rather than enables. Meaning that the drive is normally enabled, and is disabled when a signal is applied. Well Stepcofig does not use any configured enables/disables in the test mode, so when you try to use the drive in Linuxcnc the drive is then disabled. If that is the problem simply inverting your enable signal is the solution.
The following user(s) said Thank You: wl
08 Oct 2018 19:52 #118558
Another common problem is that you might have had Steoconfig configured to create a simulation config. It is a small checkbox on the first page.
Time to create page: 0.406 seconds
