SPINDLE LOWPASS GAIN EFFECTING ATC
29 Nov 2018 18:08 #121600
by COlger81
SPINDLE LOWPASS GAIN EFFECTING ATC was created by COlger81
If i set spindle lowpass gain lower than 1, it causes a very small varying reading on spindle out. This is causing my atc cycle to stop due to spindle not being at speed. Any help would be appreciated.
- Thank you received: 1370
29 Nov 2018 18:17 #121601
Replied by Todd Zuercher on topic SPINDLE LOWPASS GAIN EFFECTING ATC
You'll need to share your config files for a more specific answer. But I think the answer will involve a near component.
29 Nov 2018 18:21 #121602
by COlger81
Replied by COlger81 on topic SPINDLE LOWPASS GAIN EFFECTING ATC
That's the odd part, i'm already using a near component.
29 Nov 2018 18:22 #121603
by COlger81
Near scale that feeds spindle at speed is set at 1.2
29 Nov 2018 18:31 #121604
Is the problem when the spindle is supposed to be stopped or when it is running?
29 Nov 2018 18:34 #121605
by COlger81
Spindle at 0 rpm, stopped.
29 Nov 2018 19:08 #121607
Do you have near.0.difference set to anything?
1.2*0 is still 0, you probably need to also set the near difference to something like 5 (or 2 or 3).
29 Nov 2018 19:33 #121608
by COlger81
Bingo, thank you Todd. Missed that parameter.
Time to create page: 0.155 seconds
