- Configuring LinuxCNC
- Basic Configuration
- Replacing Breakout board by machdrives 6 Axis Breakout Board
20 Jan 2019 21:23 #124495
by seuchato
Hi all
I am experiencing troubles with the breakout board I have. I swapped the controlling pc, cable, amplifiers and stepper motors including the cables to the motors. What remains is the breakout board. Sooner or later, I will convert to servo drives. I already have some decent DC motors, for which I plan to use the BRC drives of machdrives.com. So, I guess, it is only obvious, I'd like to use their breakout board BBC (see manual here: machdrives.com/pdf/BBC%20User%20Manual.pdf.
To me, their BBC looks very nice. Checking for references and use cases with linuxcnc, I could not find any. Does anyone have experience with machdrives.com?
Greetings
chris
Greetings
chris
21 Jan 2019 09:48 #124512
by pl7i92
Replied by pl7i92 on topic Replacing Breakout board by machdrives 6 Axis Breakout Board
the board uses a standard Pinout
so No
problem on That
but why not going for a Mach3 5Axis China one it has a Spindle controller for VFD already onboard and some more featuers to be better then this Board
so No
problem on That
21 Jan 2019 10:35 #124521
by seuchato
Replied by seuchato on topic Replacing Breakout board by machdrives 6 Axis Breakout Board
pl7i92
Thanx a ton! Found one here: www.amazon.com/Breakout-optical-coupler-...Driver/dp/B00WN4T23W
Greez
chris
Greez
chris
