The last value of G54 offset
23 Jan 2019 12:49 #124663
by kibo
The last value of G54 offset was created by kibo
Hello
I set the G54 offsets in the Axis GUI. I worked and finally switched the machine off.
The following day, I updated my computer and after running LinuxCNC I got zero values of G54 offsets in the Axis GUI.
Is it possible to find the exact values of G54 offsets now?
I've edited the file linux_cnc.var and linux_cnc.var.back, but in those files are only zeros values.
Thanks a lot.
Tomas
Thanks a lot.
Tomas
24 Jan 2019 01:10 #124701
Replied by andypugh on topic The last value of G54 offset
This is unexpected. A LinuxCNC update would normally leave the .vars file (where the offsets are stored) untouched, and the offsets would persist.
What did you update to, and from?
But, surely it can't be _that_ hard to recover the offsets by touching-off to the fixtures or half-finished workpiece?
The following user(s) said Thank You: kibo
27 Jan 2019 15:39 - 27 Jan 2019 15:40 #124975
by kibo
Replied by kibo on topic The last value of G54 offset
Hi. Thanks for reply.
Thanks a lot.
I have not updated for several months. It was a big update. A lot of packages from default resources in LinuxCNC 2.7."What did you update to, and from?"
I did it."But, surely it can't be _that_ hard to recover the offsets by touching-off to the fixtures or half-finished workpiece?"
Thanks a lot.
Last edit: 27 Jan 2019 15:40 by kibo.
Time to create page: 0.161 seconds
