- Configuring LinuxCNC
- Basic Configuration
- Successful stepconf user buys Mesa5i25 wants to use experience in pncconf. How??
20 Jul 2019 21:43 #140008
Replied by PCW on topic Successful stepconf user buys Mesa5i25 wants to use experience in pncconf. How??
What files you need to edit depends on the use of the other G540.
If the other G540 is used to drive other joints/axis you will need to
edit both the hal and ini files to setup the other joints/axis
"num" probably refers to the stepgen/pwmgen/gpio instance
20 Jul 2019 22:01 - 20 Jul 2019 22:01 #140009
by GaryLa
Replied by GaryLa on topic Successful stepconf user buys Mesa5i25 wants to use experience in pncconf. How??
About the HAL, that's what I was thinking/hoping.
I thought that, too about the "Num" column. But the numbers go as high as 33.
Also, what would be the difference between Num 000 and Num 0 ?
Both can't be an instance of zero, can they?
Last edit: 20 Jul 2019 22:01 by GaryLa.
- Thank you received: 5946
20 Jul 2019 22:31 #140013
Replied by tommylight on topic Successful stepconf user buys Mesa5i25 wants to use experience in pncconf. How??
num = number of
20 Jul 2019 22:42 #140015
I think pncconf uses the hal pin instance field name so
things like GPIO pins might have 3 digits but other hardware
might have only 1 or 2.
The following user(s) said Thank You: GaryLa
Time to create page: 0.205 seconds
