Setting up a 5i25/G540/7i76 Gantry
15 Feb 2019 14:49 - 15 Feb 2019 14:57 #126548
by MartyJ
Replied by MartyJ on topic Setting up a 5i25/G540/7i76 Gantry
OK. I have the 7i76 plugged in to the P3 (onboard) and G540 plugged into the P2 header. I used the 5i25_g540_7i76.bit firmware.
Configuration Name: HOSTMOT2
BoardName : MESA5I25
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: PWM
There are 1 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: QCount
There are 2 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: StepGen
There are 10 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort StepGen 0 Dir/Table2 (Out)
14 1 IOPort StepGen 0 Step/Table1 (Out)
2 2 IOPort StepGen 1 Dir/Table2 (Out)
15 3 IOPort StepGen 1 Step/Table1 (Out)
3 4 IOPort StepGen 2 Dir/Table2 (Out)
16 5 IOPort StepGen 2 Step/Table1 (Out)
4 6 IOPort StepGen 3 Dir/Table2 (Out)
17 7 IOPort StepGen 3 Step/Table1 (Out)
5 8 IOPort StepGen 4 Dir/Table2 (Out)
6 9 IOPort StepGen 4 Step/Table1 (Out)
7 10 IOPort SSerial 0 TXData1 (Out)
8 11 IOPort SSerial 0 RXData1 (In)
9 12 IOPort SSerial 0 TXData2 (Out)
10 13 IOPort SSerial 0 RXData2 (In)
11 14 IOPort QCount 0 Quad-IDX (In)
12 15 IOPort QCount 0 Quad-B (In)
13 16 IOPort QCount 0 Quad-A (In)
IO Connections for P2
1 17 IOPort None
14 18 IOPort PWM 0 PWM (Out)
2 19 IOPort StepGen 5 Step/Table1 (Out)
15 20 IOPort None
3 21 IOPort StepGen 5 Dir/Table2 (Out)
16 22 IOPort StepGen 9 Step/Table1 (Out)
4 23 IOPort StepGen 6 Step/Table1 (Out)
17 24 IOPort None
5 25 IOPort StepGen 6 Dir/Table2 (Out)
6 26 IOPort StepGen 7 Step/Table1 (Out)
7 27 IOPort StepGen 7 Dir/Table2 (Out)
8 28 IOPort StepGen 8 Step/Table1 (Out)
9 29 IOPort StepGen 8 Dir/Table2 (Out)
10 30 IOPort QCount 1 Quad-A (In)
11 31 IOPort QCount 1 Quad-B (In)
12 32 IOPort QCount 1 Quad-IDX (In)
13 33 IOPort None
Last edit: 15 Feb 2019 14:57 by MartyJ.
15 Feb 2019 14:58 - 15 Feb 2019 15:10 #126549
Replied by PCW on topic Setting up a 5i25/G540/7i76 Gantry
Right, so GPIO0 is the 7I76s stepgen 5 pin (so not usable as GPIO unless you disable the stepgen)
Also that bit file does not match mine which has the G540 on P3 and G540 stepgens 0..4:
FPGA Size: 9 KGates
FPGA Pins: 144
IDROM Type: 3
IDROM Type: 3
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: StepGen
Version: 2
Registers: 10
BaseAddress: 2000
Module: PWMGen
There are 1 of PWMGen in configuration
Version: 0
Registers: 5
BaseAddress: 4100
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
1 0 IOPort None
14 1 IOPort PWMGen 0 PWM (Out)
2 2 IOPort StepGen 0 Step (Out)
15 3 IOPort None
3 4 IOPort StepGen 0 Dir (Out)
16 5 IOPort StepGen 4 Step (Out)
4 6 IOPort StepGen 1 Step (Out)
17 7 IOPort None
5 8 IOPort StepGen 1 Dir (Out)
6 9 IOPort StepGen 2 Step (Out)
7 10 IOPort StepGen 2 Dir (Out)
8 11 IOPort StepGen 3 Step (Out)
9 12 IOPort StepGen 3 Dir (Out)
10 13 IOPort QCount 0 Quad-A (In)
11 14 IOPort QCount 0 Quad-B (In)
12 15 IOPort QCount 0 Quad-IDX (In)
13 16 IOPort None
1 17 IOPort StepGen 5 Dir (Out)
14 18 IOPort StepGen 5 Step (Out)
2 19 IOPort StepGen 6 Dir (Out)
15 20 IOPort StepGen 6 Step (Out)
3 21 IOPort StepGen 7 Dir (Out)
16 22 IOPort StepGen 7 Step (Out)
4 23 IOPort StepGen 8 Dir (Out)
17 24 IOPort StepGen 8 Step (Out)
5 25 IOPort StepGen 9 Dir (Out)
6 26 IOPort StepGen 9 Step (Out)
7 27 IOPort SSerial 0 TXData1 (Out)
8 28 IOPort SSerial 0 RXData1 (In)
9 29 IOPort SSerial 0 TXData2 (Out)
10 30 IOPort SSerial 0 RXData2 (In)
11 31 IOPort QCount 1 Quad-IDX (In)
12 32 IOPort QCount 1 Quad-B (In)
13 33 IOPort QCount 1 Quad-A (In)
Last edit: 15 Feb 2019 15:10 by PCW.
15 Feb 2019 15:28 #126555
by MartyJ
I guess I have two issues I need to solve
1. What firmware should I be using in order to get a G540 and 7i76 running off of my 5i25?
2. Once that's sorted, what does a proper HAL file look like for that? I think this step will be straightforward once we are sure my 5i25 is set up correctly.
15 Feb 2019 15:34 #126558
Either firmware should work but it looks like your bitfile puts the G540 on P2 and assigns it the higher numbered stepgens. because of that the hal file stepgen numbering and GPIO pin numbering would be different.
AFAICT you are trying to use example hal files setup for standard G540_7I76 firmware but you have firmware with swapped connectors. Where did you get that firmware?
15 Feb 2019 15:41 - 15 Feb 2019 15:45 #126560
by MartyJ
Looks like this BIT file doesn't produce the result described in the PIN file.
Got it from the Support section of the 5i25 page on Mesaus.com.
Current output of mesaflash --device 5i525 --readhmid
5i25_g540_7i76.bit:
FPGA Size: 9 KGates
FPGA Pins: 144
IDROM Type: 3
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: PWM
Version: 0
Registers: 5
BaseAddress: 4100
Module: QCount
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: StepGen
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
1 17 IOPort None
15 20 IOPort None
17 24 IOPort None
13 33 IOPort None
5i25_g540_7i76.bit:
FPGA Size: 9 KGates
FPGA Pins: 144
IDROM Type: 3
IDROM Type: 3
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: StepGen
Version: 2
Registers: 10
BaseAddress: 2000
Module: PWMGen
Version: 0
Registers: 5
BaseAddress: 4100
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
1 0 IOPort None
15 3 IOPort None
17 7 IOPort None
13 16 IOPort None
Last edit: 15 Feb 2019 15:45 by MartyJ.
15 Feb 2019 15:52 - 15 Feb 2019 16:07 #126563
by MartyJ
OK so P2 and P3 are swapped, no big deal, I think if I plug my G540 into P2 and use the higher number stepgens I should be able to make the rest of this work. Going to give that a try.
Last edit: 15 Feb 2019 16:07 by MartyJ.
15 Feb 2019 16:10 #126565
Sorry I must have accidentally copied the 7i76_g540 bitfile on top of the
g540_7i76 bitfile at some point
Here is the proper g540_7i76 bitfile
freeby.mesanet.com/5i25_g540_7i76.bit
The following user(s) said Thank You: MartyJ
15 Feb 2019 18:42 - 15 Feb 2019 18:43 #126578
by MartyJ
Is there anything else I need to do? In this thread, a user mentioned needing to put an XML file in /lib/firmware and creating a 5i25 folder. Is that a thing?
forum.linuxcnc.org/27-driver-boards/2934...-5i25-7i76-confusion
Here's my current HAL file. It causes LinuxCNC to fail to load. I don't know how much simpler I can make it.
loadrt [KINS]KINEMATICS
loadrt motmod servo_period_nsec=1000000 num_joints=4
loadrt hostmot2
loadrt hm2_pci config="num_stepgens=5"
loadrt pid names=pid.0,pid.1,pid.2,pid.3
setp hm2_5i25.0.watchdog.timeout_ns 5000000
#CHARGE PUMP
setp hm2_5i25.0.stepgen.04.control-type 1
setp hm2_5i25.0.stepgen.04.position-scale 1
setp hm2_5i25.0.stepgen.04.velocity-cmd 16000
setp hm2_5i25.0.stepgen.04.steplen 62500
net machine-is-enabled hm2_5i25.0.stepgen.04.enable
# external output signals
# external input signals
# --- HOME-ALL ---
net home-ALL <= hm2_5i25.0.gpio.002.in
# JOINT 0 (X)
setp pid.0.Pgain [JOINT_0]P
setp pid.0.Igain [JOINT_0]I
setp pid.0.Dgain [JOINT_0]D
setp pid.0.bias [JOINT_0]BIAS
setp pid.0.FF0 [JOINT_0]FF0
setp pid.0.FF1 [JOINT_0]FF1
setp pid.0.FF2 [JOINT_0]FF2
setp pid.0.deadband [JOINT_0]DEADBAND
setp pid.0.maxoutput [JOINT_0]MAX_OUTPUT
setp pid.0.error-previous-target true
# Step Gen signals/setup
setp hm2_5i25.0.stepgen.00.dirsetup [JOINT_0]DIRSETUP
setp hm2_5i25.0.stepgen.00.dirhold [JOINT_0]DIRHOLD
setp hm2_5i25.0.stepgen.00.steplen [JOINT_0]STEPLEN
setp hm2_5i25.0.stepgen.00.stepspace [JOINT_0]STEPSPACE
setp hm2_5i25.0.stepgen.00.position-scale [JOINT_0]STEP_SCALE
setp hm2_5i25.0.stepgen.00.step_type 0
setp hm2_5i25.0.stepgen.00.control-type 1
setp hm2_5i25.0.stepgen.00.maxaccel [JOINT_0]STEPGEN_MAXACCEL
setp hm2_5i25.0.stepgen.00.maxvel [JOINT_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net 0-pos-cmd <= joint.0.motor-pos-cmd
net 0-vel-cmd <= joint.0.vel-cmd
net 0-output <= hm2_5i25.0.stepgen.00.velocity-cmd
net 0-pos-fb <= hm2_5i25.0.stepgen.00.position-fb
net 0-pos-fb => joint.0.motor-pos-fb
net 0-enable <= joint.0.amp-enable-out
net 0-enable => hm2_5i25.0.stepgen.00.enable
# ---setup home / limit switch signals---
net home-all => joint.0.home-sw-in
net home-all => joint.0.neg-lim-sw-in
# JOINT 3 (X)
setp pid.0.Pgain [JOINT_3]P
setp pid.0.Igain [JOINT_3]I
setp pid.0.Dgain [JOINT_3]D
setp pid.0.bias [JOINT_3]BIAS
setp pid.0.FF0 [JOINT_3]FF0
setp pid.0.FF1 [JOINT_3]FF1
setp pid.0.FF2 [JOINT_3]FF2
setp pid.0.deadband [JOINT_3]DEADBAND
setp pid.0.maxoutput [JOINT_3]MAX_OUTPUT
#setp hm2_5i25.0.stepgen.03.invert_output 1
setp hm2_5i25.0.stepgen.03.dirsetup [JOINT_3]DIRSETUP
setp hm2_5i25.0.stepgen.03.dirhold [JOINT_3]DIRHOLD
setp hm2_5i25.0.stepgen.03.steplen [JOINT_3]STEPLEN
setp hm2_5i25.0.stepgen.03.stepspace [JOINT_3]STEPSPACE
setp hm2_5i25.0.stepgen.03.position-scale [JOINT_3]STEP_SCALE
setp hm2_5i25.0.stepgen.03.step_type 0
setp hm2_5i25.0.stepgen.03.control-type 1
setp hm2_5i25.0.stepgen.03.maxaccel [JOINT_3]STEPGEN_MAXACCEL
setp hm2_5i25.0.stepgen.03.maxvel [JOINT_3]STEPGEN_MAXVEL
net 3-pos-cmd <= joint.3.motor-pos-cmd
net 3-vel-cmd <= joint.3.vel-cmd
net 3-output <= hm2_5i25.0.stepgen.03.velocity-cmd
net 3-pos-fb <= hm2_5i25.0.stepgen.03.position-fb
net 3-pos-fb => joint.3.motor-pos-fb
net 3-enable <= joint.3.amp-enable-out
net 3-enable => hm2_5i25.0.stepgen.03.enable
net home-all => joint.3.home-sw-in
net home-all => joint.3.neg-lim-sw-in
# JOINT 1 (Y)
setp pid.1.Pgain [JOINT_1]P
setp pid.1.Igain [JOINT_1]I
setp pid.1.Dgain [JOINT_1]D
setp pid.1.bias [JOINT_1]BIAS
setp pid.1.FF0 [JOINT_1]FF0
setp pid.1.FF1 [JOINT_1]FF1
setp pid.1.FF2 [JOINT_1]FF2
setp pid.1.deadband [JOINT_1]DEADBAND
setp pid.1.maxoutput [JOINT_1]MAX_OUTPUT
setp pid.1.error-previous-target true
net 1-index-enable <=> pid.1.index-enable
net 1-enable => pid.1.enable
net 1-pos-cmd => pid.1.command
net 1-vel-cmd => pid.1.command-deriv
net 1-pos-fb => pid.1.feedback
net 1-output => pid.1.output
setp hm2_5i25.0.stepgen.01.dirsetup [JOINT_1]DIRSETUP
setp hm2_5i25.0.stepgen.01.dirhold [JOINT_1]DIRHOLD
setp hm2_5i25.0.stepgen.01.steplen [JOINT_1]STEPLEN
setp hm2_5i25.0.stepgen.01.stepspace [JOINT_1]STEPSPACE
setp hm2_5i25.0.stepgen.01.position-scale [JOINT_1]STEP_SCALE
setp hm2_5i25.0.stepgen.01.step_type 0
setp hm2_5i25.0.stepgen.01.control-type 1
setp hm2_5i25.0.stepgen.01.maxaccel [JOINT_1]STEPGEN_MAXACCEL
setp hm2_5i25.0.stepgen.01.maxvel [JOINT_1]STEPGEN_MAXVEL
net 1-pos-cmd <= joint.1.motor-pos-cmd
net 1-vel-cmd <= joint.1.vel-cmd
net 1-output <= hm2_5i25.0.stepgen.01.velocity-cmd
net 1-pos-fb <= hm2_5i25.0.stepgen.01.position-fb
net 1-pos-fb => joint.1.motor-pos-fb
net 1-enable <= joint.1.amp-enable-out
net 1-enable => hm2_5i25.0.stepgen.01.enable
net home-all => joint.1.home-sw-in
net home-all => joint.1.neg-lim-sw-in
# JOINT 2 (Z)
setp pid.2.Pgain [JOINT_2]P
setp pid.2.Igain [JOINT_2]I
setp pid.2.Dgain [JOINT_2]D
setp pid.2.bias [JOINT_2]BIAS
setp pid.2.FF0 [JOINT_2]FF0
setp pid.2.FF1 [JOINT_2]FF1
setp pid.2.FF2 [JOINT_2]FF2
setp pid.2.deadband [JOINT_2]DEADBAND
setp pid.2.maxoutput [JOINT_2]MAX_OUTPUT
setp pid.2.error-previous-target true
net 2-index-enable <=> pid.2.index-enable
net 2-enable => pid.2.enable
net 2-pos-cmd => pid.2.command
net 2-vel-cmd => pid.2.command-deriv
net 2-pos-fb => pid.2.feedback
net 2-output => pid.2.output
setp hm2_5i25.0.stepgen.02.dirsetup [JOINT_2]DIRSETUP
setp hm2_5i25.0.stepgen.02.dirhold [JOINT_2]DIRHOLD
setp hm2_5i25.0.stepgen.02.steplen [JOINT_2]STEPLEN
setp hm2_5i25.0.stepgen.02.stepspace [JOINT_2]STEPSPACE
setp hm2_5i25.0.stepgen.02.position-scale [JOINT_2]STEP_SCALE
setp hm2_5i25.0.stepgen.02.step_type 0
setp hm2_5i25.0.stepgen.02.control-type 1
setp hm2_5i25.0.stepgen.02.maxaccel [JOINT_2]STEPGEN_MAXACCEL
setp hm2_5i25.0.stepgen.02.maxvel [JOINT_2]STEPGEN_MAXVEL
net 2-pos-cmd <= joint.2.motor-pos-cmd
net 2-vel-cmd <= joint.2.vel-cmd
net 2-output <= hm2_5i25.0.stepgen.02.velocity-cmd
net 2-pos-fb <= hm2_5i25.0.stepgen.02.position-fb
net 2-pos-fb => joint.2.motor-pos-fb
net 2-enable <= joint.2.amp-enable-out
net 2-enable => hm2_5i25.0.stepgen.02.enable
net home-all => joint.2.home-sw-in
net home-all => joint.2.pos-lim-sw-in
# ---motion control signals---
#net in-position <= motion.in-position
#net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
#net estop-out <= iocontrol.0.user-enable-out
net estop-out <= hm2_5i25.0.gpio.003.in_not
net estop-out => iocontrol.0.emc-enable-in
Last edit: 15 Feb 2019 18:43 by MartyJ.
15 Feb 2019 18:46 #126579
by MartyJ
FWIW there is no 5i25 folder in my /lib/firmware/hm2
15 Feb 2019 18:54 #126580
Neither the firmware folder nor .xml files are required unless you are using pncconf to create a configuration
If LinuxCNC will not load a hal file it should print out the offending hal line
(assuming you are running this from the command line)
Time to create page: 0.214 seconds
