How to increase Angular Velocity
15 Mar 2019 00:16 - 15 Mar 2019 00:58 #128618
by ljask
How to increase Angular Velocity was created by ljask
I'm running the axis_9axis simulator. Before I 'Home All' axes I can jog the A axis at high speed. (I bumped up all the MAX_VELOCITY / MAX_ANGULAR_VELOCITY parameters I could find.) After homing, the angular velocity is clamped at 60 (1 deg. / sec.). Any ideas why?
Update: When I "Unhome" the U axis (all other axes are homed) the A axis jog speed returns to normal.
Also, I am running a real 4 axis machine using the standard Sherline configuration. It too has the A axis velocity (as show in the Preview screen) at 60--and that is exactly what the rotary table does, turn 1 deg. / sec. I don't have access to that machine just now, but I think the issues are related. Any thoughts? Thanks.
Last edit: 15 Mar 2019 00:58 by ljask.
15 Mar 2019 01:51 #128625
by dgarrett
Replied by dgarrett on topic How to increase Angular Velocity
Version not specified but guessing it is master branch (2.8~pre), in the
axis_9axis.ini sim config set the AXIS_A vel/accel limits to conform to its
identity joint (JOINT_3) values:
[AXIS_A]
MAX_VELOCITY = 90
MAX_ACCELERATION = 1200
15 Mar 2019 07:54 #128641
by pl7i92
Replied by pl7i92 on topic How to increase Angular Velocity
look into display Section
if it is not taken down to a lower value
LIMITED
linuxcnc.org/docs/html/config/ini-config.html
DEFAULT_ANGULAR_VELOCITY = .25 - The default velocity for angular jogs, in machine units per second.
MIN_ANGULAR_VELOCITY = .01 - The approximate lowest value the angular jog slider.
MAX_ANGULAR_VELOCITY = 65.0 - The maximum velocity for angular jogs, in machine units per second.
LIMITED
15 Mar 2019 13:52 - 15 Mar 2019 13:56 #128656
by ljask
Replied by ljask on topic How to increase Angular Velocity
Setting
[AXIS_A]
MAX_VELOCITY = 90
MAX_ACCELERATION = 1200 worked! These parameters were missing in the sample file so I added them.
How is it related to homing? I have a lot to learn. Thanks.
[AXIS_A]
MAX_VELOCITY = 90
Last edit: 15 Mar 2019 13:56 by ljask.
15 Mar 2019 14:38 #128658
Replied by andypugh on topic How to increase Angular Velocity
Before you home the machine is in "Joint mode" where you can jog each joint separately.
After homing the machine switches to "World" mode, where you jog the tool-tip in the XYZABC coordinate system.
On many machines the difference between joints and axes is hard to see, but consider a robot arm. With a robot arm you can either jog each elbow joint individually, or you can move the tool around in cartesian coordinate axis space.
The following user(s) said Thank You: ljask
16 Mar 2019 14:09 #128739
by pl7i92
you shoudt considder a new MAIN Stepconf file as you edited it from a older system and this may trouble again
as starting with known numbering to a clear stepconf Basic configuration
16 Mar 2019 17:05 - 16 Mar 2019 17:08 #128754
by ljask
Related to this, when on a real machine (I'm using the stick Sherline4Axis ini file) I jog the X, Y and Z axes from the keyboard and get a fairly rapid response. When I jog the A axis, it takes 5 sec. or so to accelerate up to full velocity (1500 deg. / in.). If I go to the MDI tab and issue a G0 Ann command, the axis responds immediately and quickly ( i.e. rapid acceleration) moves to the commanded position. None of this is a problem, but I am curious as to what is slowing the acceleration for the keyboard jogs? I am using 2.7.8 and axis interface.
Last edit: 16 Mar 2019 17:08 by ljask. Reason: typo
18 Mar 2019 12:36 #128887
by pl7i92
please update to 2.7.14
the issue is inside the interpreter
is the Alowed speed at 100% set
Time to create page: 0.120 seconds
