Tool change position different for ATC and Manuell TC
23 Mar 2019 14:37 #129363
by pl7i92
Tool change position different for ATC and Manuell TC was created by pl7i92
Hi is it possible to have for the first 6 tools as in ATC a different toolchange position then for the Tools Nr above 6
24 Mar 2019 01:37 #129420
Replied by andypugh on topic Tool change position different for ATC and Manuell TC
Not using G38 or the built-in retract.
But if you remap the M6 command, then you can do this easily.
The following user(s) said Thank You: pl7i92
24 Mar 2019 07:37 #129446
by pl7i92
Replied by pl7i92 on topic Tool change position different for ATC and Manuell TC
i thik im out of mind as i did remap the M6
not getting this in
THANK you
not getting this in
THANK you
Time to create page: 0.143 seconds
