7i76 limits question..
29 Mar 2019 21:08 #129926
by B_Casey
7i76 limits question.. was created by B_Casey
when the signal is not inverted the switches show joint 0 and joint one on limit switch error.
so i inverted the signals.. now the switches to not register at all.
have tested the switches with a meter, the switches are working
the e-stop is doing the same thing...
not sure what could be causing this issue, (the same switches and e-stops where functioning fine on the 5i25-g540 before i put the 7i76
12v field power
5v other power
both leds are on
field pwr ->switch -> input on 7i76
Brian
12v field power
5v other power
both leds are on
Brian
30 Mar 2019 14:54 #129971
by B_Casey
Replied by B_Casey on topic 7i76 limits question..
figured this out, it was a typo in the server period thing, was causing the sserial to shut down due to errors, (left off one of the zeros)
- Thank you received: 5944
30 Mar 2019 22:10 #130000
Replied by tommylight on topic 7i76 limits question..
Thank you for reporting back.
Glad you got it working.
The following user(s) said Thank You: B_Casey
31 Mar 2019 02:30 #130010
Replied by PCW on topic 7i76 limits question..
You should have gotten a cascade of error messages if you lost contact with the 7I76
If you want to generate a fault if you lose contact with a sserial remote, you can use the
hm2_(card).0.sserial.port-0.run
pin to monitor the health of sserial connections
31 Mar 2019 02:34 #130011
by B_Casey
there was and your response to someone else some other when clued me into what the problem was !
Time to create page: 0.206 seconds
