Question on half step config
- Thank you received: 1370
01 Apr 2019 15:20 #130103
Replied by Todd Zuercher on topic Question on half step config
I don't think that really applies to these. Newer bipolar drives can have better performance and are significantly cheaper to replace than these old uni-polar drives. I'll continue to repair the old ones if I can, but I doubt I'll ever buy another one.
- allenwg2005
- Topic Author
- Thank you received: 4
01 Apr 2019 21:06 #130118
by allenwg2005
Replied by allenwg2005 on topic Question on half step config
I email AA to determine what the proper way would be to half step with the drive I mentioned earlier; and if just disconnecting the terminal in question would be appropriate, here's a copy of the response:
"I was suggesting this for testing purposes, the best way to do this would be to designate that terminal as open through the controller. I would not know how you would do that with your controller however."
Any ideas on how to "designate" the terminal in LCNC?
01 Apr 2019 23:25 #130122
If you currently have that pin connected to an output on your Linuxcnc computer and Linuxcnc is commanding that output. You probably only need to find that parallel port output pin in your hal file and comment it out (probably a setp line). I will be honest none of the machines I've worked with use that pin. If yours is using the whole step input it is most likely just a direct connection to 5v or ground and not wasting an output. I have the documents for the drives at work I just can't remember what they say whether the pin needs pulled high or low for full steps. But I know disconnected is half
02 Apr 2019 13:47 #130156
I looked up the manual today, "Logic 0" for full stepps is pin 8 pulled low (connected to ground). "Logic 1" is pin 8 high, 3.5-24v and it will float there if disconnected.
- Mike_Eitel
- Thank you received: 185
02 Apr 2019 15:53 #130160
by Mike_Eitel
Replied by Mike_Eitel on topic Question on half step config
I hate floating pins.
They always bite when you have no time for trouble. Fix it to either potential.
m5c
Mike
m5c
Mike
02 Apr 2019 16:17 #130162
Maybe I used bad terminology, the drive has an internal pull up, so the pin is either high or pulled low by something you've connected to it.
- Mike_Eitel
02 Apr 2019 17:16 #130165
by Mike_Eitel
Better felling
08 Apr 2019 12:46 #130502
by pl7i92
Replied by pl7i92 on topic Question on half step config
@125mike did this solve your problem as we like to here the GOOD news
- allenwg2005
- Topic Author
08 Apr 2019 13:27 #130507
by allenwg2005
Sorry,
Took out pin 8 from hal, removed wire from term 8 and it's half stepping.
09 Apr 2019 15:33 #130557
by pl7i92
great to Here
if you do not mind can you make a simple sheme on wirerup that kind of driver to the BOB
Time to create page: 0.127 seconds
