axises are dead after configuration
19 Apr 2019 06:58 #131225
by pl7i92
Replied by pl7i92 on topic axises are dead after configuration
if you give us here a little more infos
like
Tb6600 microsteps 2 = 400steps/rev
Leadscrew 1605
Timingbelt pulley 20 on motor pulley 25 on leadscrew
Brekout board C10
THAT woudt help us
like
Leadscrew 1605
Brekout board C10
THAT woudt help us
20 Apr 2019 02:56 #131268
Yes I'm a developer for linuxcnc - I work more on GUI code then anything else. I've dabbled with some things in the 'core'.
One reason linuxcnc use files as it does is that kernel/realtime code access then and there are limitations to what they can use.
Saying that, there surely are many modern updates that would help linuxcnc be easier to use/develop.
It a catch 22 though - we need more devs to audit and update code, but the code is difficult to work on.
The linuxcnc dev hierarchy is in rough shape at the moment IMHO - but I'm sure that will improve with time.
Andy has an experimental branch that had the toolfile as a database - i think he got discouraged by the lack of communication about it - I hope he tries again.
Chris M
Replied by cmorley on topic axises are dead after configuration
Hi Chris,
it is my understanding that you are developer for linuxcnc.
May I propose to use sqlite for all linuxcnc configurations settings instead of linuxcnc.var and the rest setting/configuration files?
I think that would significantly simplify development/configuration/usage.
sqlite is present practically everywhere on every platform. it is fast and small. its file/database is self-contained, so, it is easy to move configured linuxcnc to another machine if needed/appropriate.
it will be much easier to develop gui as well as all the settings/configurations can be read from it.
I see some other benefits as well.
Regards,
Slava
Chris M
20 Apr 2019 03:11 #131270
by sm
Replied by sm on topic axises are dead after configuration
yes, I saw in source an attempt to use db. well... you most likely know all this, so, I just wanted to remind - sqlite is fast, most used db. it is in-file db. but it can be also made in-memory db, which will make it even faster. python has well implemented libs to interact with sqlite and it is quite easy to deal with sqlite in python. in c it is a bit more challenging, but still doable.
I don't want to waste your time here - just wanted to say, that I think it will be lots benefits if sqlite will be used instead of plain files.
oh...while I remember... XY only CNC machines are not weird (like foam cutting machine for example) - they just differ from traditional ones.
Time to create page: 0.096 seconds
