- Configuring LinuxCNC
- Basic Configuration
- INIFILE: ERR_CONVERSION for gantry configuration (2.8.0-pre1-4740-g60416609a)
03 Jun 2019 09:41 #135724
by JetForMe
I do. Y1/Y2 are 0, X is 1, I turned off Z for now because I didn't want to deal with it for the moment (it also needs different values I haven't figured out yet).
I don't understand what you mean by “both -ve”?
Replied by JetForMe on topic INIFILE: ERR_CONVERSION for gantry configuration (2.8.0-pre1-4740-g60416609a)
Do you have Y1 and Y2 both with the same sequence number and both -ve in the ini file
HOME_SEQUENCE = -1
03 Jun 2019 10:10 - 03 Jun 2019 10:10 #135725
Replied by rodw on topic INIFILE: ERR_CONVERSION for gantry configuration (2.8.0-pre1-4740-g60416609a)
As long as you have the negative home sequence, pretty sure Linuxcnc won't let you jog before homing. Just hit the home all button and it should work.... finger on red button.
Last edit: 03 Jun 2019 10:10 by rodw.
03 Jun 2019 10:12 #135726
Just check for Y and Y1 you have
HOME_SEQUENCE = -1
as Clive said!
HOME_SEQUENCE = -1
as Clive said!
03 Jun 2019 10:15 - 03 Jun 2019 10:16 #135727
WARNING:
Just going back to one of your posts and you linked to homing docs for V2.7 which are WRONG for master branch/2.8
go here linuxcnc.org/docs/devel/html/config/ini-homing.html
Read what it says about negative homing sequences as you might be on the wrong page to Clive and I.
Last edit: 03 Jun 2019 10:16 by rodw.
03 Jun 2019 13:56 - 03 Jun 2019 16:10 #135751
by BigJohnT
Those values don't come from my configuration tool, I suspect the LinuxCNC conversion tool is the culprit. I'll have to test later today after work. IIRC the LinuxCNC conversion tool wants version 1.2 and my tool is using 1.1.
Edit: I just did a git pull and checked out 2.8 branch and grepped for YLeftMax and did not find that, so now I have no clue where that came from.
Also, I never start a variable with a capitol letter if I had wrote that it would be "yLeftMax".
JT
Replied by BigJohnT on topic INIFILE: ERR_CONVERSION for gantry configuration (2.8.0-pre1-4740-g60416609a)
Errors like:
INIFILE: ERR_CONVERSION, section=JOINT_0, tag=HOME, num=1, lineNo=105
are due to the following bogus ini file entries:... [JOINT_0] HOME = Xmin ... [JOINT_1] HOME = YLeftMax ... [JOINT_2] HOME = YRightMax ... [JOINT_3] HOME = ZMax ...
The values for HOME= must be numeric.
If these lines were created by a configuration tool,
it is broken.
linuxcnc.org/docs/devel/html/getting-sta...dating-linuxcnc.html
JT
Last edit: 03 Jun 2019 16:10 by BigJohnT.
03 Jun 2019 16:53 #135760
by BigJohnT
I also grepped my entire github and LinuxCNC 2.7, 2.8 and master but those words are not there.
JT
JT
03 Jun 2019 19:00 #135776
by JetForMe
Well, I want these in the Home All sequence. I just want to be able to home my Y axis separately from X and Z, and there seems to be no way to do that. I don't want to ever home J1 or J2 independently (certainly not easily), because that could cause damage. I can Home All and it does the right thing for Y, but I fear it only does that because I have the same homing sequence set for them.
HOME_SEQUENCE = -1
as Clive said!
03 Jun 2019 19:14 #135779
by JetForMe
One question: I'm looking at the
gantry
docs. Do I need to include that in my config? Things seem to be working without it, but it seems like it offers some things I want.
03 Jun 2019 20:12 #135790
by Clive S
What do you mean by : Do I need to include that in my config? What is it that you are trying to achieve?
It always helps to include the ini and hal files when asking any questions
Replied by Clive S on topic INIFILE: ERR_CONVERSION for gantry configuration (2.8.0-pre1-4740-g60416609a)
One question: I'm looking at the gantry docs. Do I need to include that in my config? Things seem to be working without it, but it seems like it offers some things I want.
03 Jun 2019 20:23 #135792
by JetForMe
I don't have an entry in my .hal right now for the gantry component. I'm asking if adding one will improve anything for me. It's working now, but I wonder what gantry would do for me.
Attached are slightly out-of-date files for what I have now.
Time to create page: 0.120 seconds
