feixt
09 Jul 2019 09:48 #138938
by felixt
Good morning:
After many attempts to configure my linuxCNC with the Stepconf Wizard
I have achieved that all three engines work perfectly.
While I'm checking the option of Test this Axis of the Stepconf Wizard everything works with millimeter accuracy (so I think the configuration must be correct), no, I explain:
When I send the milling machine to cut a piece (after housings the axes) they do not rotate although they really turn but so slowly that you can not see and you hear a rumor in the engines.
It is exactly like the hands of a clock (the minute hand) that you do not see them spin but they really rotate.
That is exactly what my engines do when they work in automatic.
If you could help me, I would greatly appreciate it.
Thank you.
Felix
Thank you.
Felix
- Thank you received: 1370
09 Jul 2019 13:28 #138949
Replied by Todd Zuercher on topic feixt
The configuration of the motors are in units per second not minutes. Check that you have not made that mistake.
The following user(s) said Thank You: felixt
