basic hal configuration for 7i96+7i77
- rockandsalt
02 Aug 2019 18:26 - 02 Aug 2019 18:29 #141215
by rockandsalt
basic hal configuration for 7i96+7i77 was created by rockandsalt
Does anybody have have a basic configuration for 7i96+7i77 board they are willing to share?
I am trying to get 1 axis working (the z axis, no limit switches or home) but I am struggling in figuring out the naming convention of the daughter card. The axis is supposed to be using by Drive 5 and Encoder 5 on the 7i77 board.
Here's what I currently have.
Last edit: 02 Aug 2019 18:29 by rockandsalt.
02 Aug 2019 18:37 #141216
Replied by PCW on topic basic hal configuration for 7i96+7i77
If you have a ini/hal file set that loads you can list all signals,pins,parameters and functions by typing:
halcmd show all > al.txt
in a terminal window
Now you have a donor file for copy pasting from (all.txt) so you don't
need to guess at names
Note you should do this with all devices connected and powered so
the 7I77 pins are included
12 Aug 2019 19:42 #141990
Replied by andypugh on topic basic hal configuration for 7i96+7i77
If you _don't_ have a HAL file that loads, you can type all the same commands on the command line using minimum options.
Then copy an paste from the terminal window
halrun
loadrt hostmot2
loadrt hm2_eth board_ip=10.10.10.10 {or 192.161.1.121}
show all
exit
Time to create page: 0.271 seconds
