Homing in Z setting strange value?
- Type_Zero_Design
- Thank you received: 7
05 Aug 2019 04:06 #141394
by Type_Zero_Design
Homing in Z setting strange value? was created by Type_Zero_Design
Hey Everyone,
Wanted to see if anyone could explain to me why when my machine homes in Z it sets the home position to positive 2"?
I got my X and Y working fine, but I cant seem to figure this out
My .INI is below
# overwritten when you run PNCconf again
[EMC]
MACHINE = TC225
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/tc225/linuxcnc/nc_files
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
DEFAULT_LINEAR_VELOCITY = 0.250000
MAX_LINEAR_VELOCITY = 20.000000
MIN_LINEAR_VELOCITY = 0.016667
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 1000000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_eth
# BOARD0=7i76e
[HAL]
HALUI = halui
HALFILE = TC225.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
[KINS]
JOINTS = 3
KINEMATICS = trivkins coordinates=XYZ
[TRAJ]
COORDINATES = XYZ
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 2.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_X]
MAX_VELOCITY = 3.33333333333
MAX_ACCELERATION = 30.0
MIN_LIMIT = -15.0
MAX_LIMIT = 0.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
STEPGEN_MAXVEL = 4.17
STEPGEN_MAXACCEL = 37.50
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = -50800.102
MIN_LIMIT = -15.0
MAX_LIMIT = 0.0
HOME_OFFSET = -1.5
HOME_SEARCH_VEL = 0.050000
HOME_LATCH_VEL = 0.016667
HOME_FINAL_VEL = 1.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
[AXIS_Y]
MAX_VELOCITY = 20.0
MAX_ACCELERATION = 50.0
MIN_LIMIT = -10.0
MAX_LIMIT = 0.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 20.0
STEPGEN_MAXVEL = 25.00
STEPGEN_MAXACCEL = 62.50
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 5000
DIRHOLD = 5000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 50800.102
MIN_LIMIT = -10.0
MAX_LIMIT = 0.0
HOME_OFFSET = -1.5
HOME_USE_INDEX = NO
HOME_SEQUENCE = 2
[AXIS_Z]
MAX_VELOCITY = 1.0
MIN_LIMIT = -7.75
MAX_LIMIT = 7.75
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 1.0
STEPGEN_MAXVEL = 1.25
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
MIN_LIMIT = -7.75
MAX_LIMIT = 7.75
HOME_OFFSET = 0.000000
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
[SPINDLE_9]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 2000
Thanks for any info!
My .INI is below
[EMC]
MACHINE = TC225
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = axis
INTRO_TIME = 5
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
[HOSTMOT2]
# DRIVER0=hm2_eth
# BOARD0=7i76e
[HAL]
HALUI = halui
HALFILE = TC225.hal
[HALUI]
[KINS]
JOINTS = 3
[TRAJ]
COORDINATES = XYZ
LINEAR_UNITS = inch
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
[AXIS_X]
MIN_LIMIT = -15.0
MAX_LIMIT = 0.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
MIN_LIMIT = -15.0
MAX_LIMIT = 0.0
HOME_OFFSET = -1.5
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
[AXIS_Y]
MAX_VELOCITY = 20.0
MIN_LIMIT = -10.0
MAX_LIMIT = 0.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 20.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 5000
DIRHOLD = 5000
STEPLEN = 5000
STEPSPACE = 5000
MIN_LIMIT = -10.0
MAX_LIMIT = 0.0
HOME_OFFSET = -1.5
HOME_USE_INDEX = NO
HOME_SEQUENCE = 2
[AXIS_Z]
MAX_VELOCITY = 1.0
MIN_LIMIT = -7.75
MAX_LIMIT = 7.75
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 1.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
MIN_LIMIT = -7.75
MAX_LIMIT = 7.75
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
[SPINDLE_9]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 2000
05 Aug 2019 06:06 #141397
by pl7i92
Replied by pl7i92 on topic Homing in Z setting strange value?
hi
the HOME is never ZERO its the position the mashine ends at the end of the homing sequence
so if your switch is at the TOP as it shoudt be
WHY do you got 50000 STEPS per inch
[AXIS_Z]
MAX_VELOCITY = 1.0
#max traveling Z is the NEG MIN
MIN_LIMIT = -7.75
MAX_LIMIT = 0.05
[JOINT_2]
TYPE = LINEAR
HOME = -0.1
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 4.0
#STEPGEN_MAXVEL = 1.25
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 20000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
MIN_LIMIT = -7.75
MAX_LIMIT = 0.05
HOME_SEARCH_VEL = 0.10
HOME_LATCH_VEL = 0.05
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
[AXIS_Z]
MAX_VELOCITY = 1.0
MIN_LIMIT = -7.75
MAX_LIMIT = 0.05
[JOINT_2]
TYPE = LINEAR
HOME = -0.1
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 4.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 20000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
MIN_LIMIT = -7.75
MAX_LIMIT = 0.05
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
- Type_Zero_Design
05 Aug 2019 21:04 #141455
by Type_Zero_Design
Replied by Type_Zero_Design on topic Homing in Z setting strange value?
pl7i92,
My home switch is in the dead center of the travel of my z axis.
AS far as the steps per inch are you refering to STEP_SCALE = -50800.102?
If so that is what was calculated and is working on my machine, dose it seem wrong?
- Type_Zero_Design
06 Aug 2019 03:23 #141470
by Type_Zero_Design
I guess what im having trouble with on Z is understanding where the 2.00 value is being generated from.
What I did on X and y is left my home_offset and home at 0 initially. Ran my homing cycle. from there I could jog the machine and watch the readout to determine what the travel was to move from the home switch to .25 short of the +LS then used that as my HOME_OFFSET to set my home as The end of my soft limit and left HOME at 0 so it positioned the table there.
As my .INI sits right now it seems to me it should come up and find home then set that home position as zero so as home is triggered my machine poisition should be zero not 2.00. that what I dont understand.
hope that makes some sense.
- Thank you received: 1370
06 Aug 2019 12:45 - 06 Aug 2019 12:45 #141520
Replied by Todd Zuercher on topic Homing in Z setting strange value?
So you are confused by the fact that your DRO says 2 when at the home position.
Do you have a G54 work coordinate offset set? (Perhaps you have an offset of 2 there.)
Last edit: 06 Aug 2019 12:45 by Todd Zuercher.
- Type_Zero_Design
06 Aug 2019 14:29 #141531
by Type_Zero_Design
Todd,
From my understanding and what I saw setting up the homing on the X and Y, That with HOME=0 and HOME_OFFSET=0 the machine should find the home switch and at latching the it should set its current location as that joints 0 position. since HOME=0 the machine should not move from that position (It stays in place in real life as expected) The thing I cant understand is where the 2.00 in the machine coordinates is coming from. Last night I tried changing HOME_OFFSET=1.0 ... That resulted in homing then moving 1.0" from the home latch position, but the machine coordinates still reported Z at 2.0"
Ill double check the work offset, but shouldn't the machine coordinate be independent of an offset? That is a position based off the Machine Coords. not the other way around.
Im sure I'm just missing something stupid but I cant quite figure it out.
06 Aug 2019 16:24 #141534
Yes the machine coordinates are independent of work coordinates, but the DRO shows the work coordinates.
- Type_Zero_Design
06 Aug 2019 17:19 #141538
by Type_Zero_Design
My DRO shows both the work and machine coords
06 Aug 2019 17:40 #141543
Replied by rodw on topic Homing in Z setting strange value?
Sometimes when configuring a new machine LInuxcnc gets confused here. various variables are stored in a file in your config folder between sessions. Usually it has a .var extension but that can be overridden in your ini file. A simple solution is to close LinuxCNC, delete this file and restart.
07 Aug 2019 06:33 #141589
by pl7i92
agree to rod delete all VAR bak.var Files of your mashine folder to get a clear var file at the start
of testing
of testing
Time to create page: 0.185 seconds
