change configs from mm to inches
14 Sep 2019 08:36 #145116
by travis036
change configs from mm to inches was created by travis036
when i first setup my CNC, i thought it would be easier to use millimetres, though i am now realizing that as i am used to working in inches, being in the US, i would like to change to inches, but without running stepconf, as it will overwrite my custom additions. is there an easy way to change my machine to inches? or is it easier to just start over?
~Travis
~Travis
- Thank you received: 5932
14 Sep 2019 09:26 #145118
Replied by tommylight on topic change configs from mm to inches
You can edit the ini file, it is easy enough.
14 Sep 2019 09:42 #145119
Change this
to
See
linuxcnc.org/docs/devel/html/config/ini-...g.html#_traj_section
Replied by rodw on topic change configs from mm to inches
Change this
LINEAR_UNITS = mm
to
LINEAR_UNITS = inch
See
14 Sep 2019 09:46 - 14 Sep 2019 09:46 #145120
by travis036
Replied by travis036 on topic change configs from mm to inches
Hmm, easier than i thought... then i just have to find all the settings in metric (like software limits, and such).
Thanks.
~Travis
Thanks.
~Travis
Last edit: 14 Sep 2019 09:46 by travis036.
14 Sep 2019 11:30 #145124
Yes, that is correct.
14 Sep 2019 14:13 #145132
by Clive S
Would a g20 in the gcode do the same job .
Replied by Clive S on topic change configs from mm to inches
Change this
LINEAR_UNITS = mm
to
LINEAR_UNITS = inch
See
14 Sep 2019 15:15 #145139
by travis036
under the AXIS, i have a SCALE of 320. i don't remember how i calculated this, so i don't know how to change it from mm to inch, or even if i need to... (been a while, and i didn't take notes as i set it up. sorry)
~Travis
~Travis
14 Sep 2019 17:02 #145146
by travis036
found this information:
not sure how to calculate scale... though in after thought, i can just run step config, and save to a different file, and grab the values i need out of it.
~Travis
200step/revolution steppers
8x microstepping
5mm ballscrew lead
~Travis
14 Sep 2019 21:43 #145177
If you had 320 steps per mm, you would have 320 * 25.4 = 8128 steps per inch
The following user(s) said Thank You: travis036
14 Sep 2019 21:51 #145179
by travis036
wow, i feel a bit dumb now, not knowing it was that simple. thought there was far more complex math involved.
maybe i just over thinked the whole process.
Thanks!
~Travis
Thanks!
~Travis
Time to create page: 0.153 seconds
