Huanyang VFD
28 Sep 2019 18:04 #146498
by Gaunt1969
Huanyang VFD was created by Gaunt1969
I have looked but have not found a good answer. Can the Huanyang VFD be controlled thru the input and output pins of a standard BOB?
I see everyone using a USB dongle or a 232 to 485 converter but can it be done with the bob?
- Thank you received: 1369
28 Sep 2019 19:52 #146502
Replied by Todd Zuercher on topic Huanyang VFD
Maybe, it depends on the breakout board. The el cheapo 5 axis Mach 3 boards with a relay and an analog out work adiquitly.
The following user(s) said Thank You: Gaunt1969
- Thank you received: 5932
28 Sep 2019 23:43 #146518
Replied by tommylight on topic Huanyang VFD
I am pretty sure i saw in one of those the possibility of setting the input for 5V or 10V, so it should be possible to control it from any BOB.
29 Sep 2019 00:14 #146525
by Gaunt1969
Replied by Gaunt1969 on topic Huanyang VFD
I was wandering about the digital out and digital in in the configuration to enable 2 way communication. is that possible to set it up as the rs485 comm to the VFD
29 Sep 2019 01:29 #146529
First, not all Huayang VFD models even have the serial control option. Second, I don't think it would be practical to try to bit bang the serial connection with a parallel port. Much simpler to use a regular serial port or usb dongel. Third, if you use regular run and analog commands the control is in real-time vs user-space like all of the serial options.
29 Sep 2019 01:35 #146530
by Gaunt1969
Thanks for the info Todd. that was kind of what I was thinking but was not sure.. It looks like I will go the 232 to 485 route.
