MDI100-199 Commands
29 Sep 2019 13:37 #146557
by amiba
MDI100-199 Commands was created by amiba
I did wrote some MDIxxx Shell Script commands and was surprised, that it gives me all the time the two Parameter P and Q over als a float even if there isn't a command given. Worse is that it gets the value of -1.0 if there isn't a Parameter named in the GCode. Because I do not see how to differ between a value of -1.0 and a not even given value.
Example:with GCode:
M100 P0 Q0 give me the output of "2 0.0 0.0"
M100 P0 give me the output of "2 0.0 -1.0"
M100 give me the output of "2 -1.0 -1.0"
Where I wanted to build a function that is working in a main usage way if no P and Q ist given and a special when it is given.
I don't know if I do something wrong because I am new to this and have much more questions.
Example:
#!/bin/bash
echo $# $1 $2 > logfile
29 Sep 2019 13:42 #146559
by pl7i92
Replied by pl7i92 on topic MDI100-199 Commands
hi
welcome you can use if then or eQ
LT GT
see the gcode to get things done your way
www.linuxcnc.org/docs/html/gcode.html
LT GT
29 Sep 2019 13:52 #146564
by amiba
Replied by amiba on topic MDI100-199 Commands
I now to write a bash script but I don't know how I get it that there is no Q or Q-1.0 or how if there is no P or P-1.0 because my script did not well because it was getting a value of -1.0 for $1 or -1.0 für $2 when in the GCode was not any input for P or Q
But I do need the value -1.0 as well and it should be a different thing than if ther isn't a value. I do want to diff the two cases: GCode M100 and M100 P-1.0 and this is actual not possible as I get always in both cases the command M100 -1.0 -1.0 what makes it impossible to decide that there isn't a P given or not.
29 Sep 2019 14:15 #146570
by pl7i92
on all systems
the -1 is NO VALUE if you inizialazise a parameter without value given
the call is like linuxcnc.org/docs/html/gcode/o-code.html#cha:o-codes shown here
Question what are you trying to adchive there might be some ready made to help you
29 Sep 2019 14:49 #146580
by amiba
ok that is a help for user. How to create such kind of functions as a predefined work around.
As for a user it should be one call like o100
that he doesn't need to write it self in each GCode that he creates for this machine.
29 Sep 2019 15:03 #146588
by amiba
there should not be a initialisation if there is no data passed through as a shell Script doesn't need unused data forwarded.
Else there is never some differ between
M100
amd
M100 P...
as I thought, that it is M100 [Pn] [Qn] and that it is possible to differ between
M100
and
M100 P-1.0
else the M100 should be force to use P and Q if it allway us it.
For example I wrote a command to give presure in Pos 1 and 2 or both.
the common way should be both so it is easy to write
M100
ready
in that function I could get the problem sorted because the value -1.0 isn't really possible
M100 P1 does it in Position 1 and
M100 P2 does it in Position 2
but what if the value that I pas is a position that can be between -1000.00 and 1002.00
Than I must pass allways the second parameter because it will not be possible to decide if their was a parameter or not.
even to use always floate is boring but I get in scripts the .0 with ${1%.*} away.
M100
amd
M100 P...
M100
and
M100 P-1.0
M100
ready
02 Oct 2019 05:28 #146859
Replied by andypugh on topic MDI100-199 Commands
You might be able to achive what you want with remapping. (that also allows more parameters).
I think you can check or which parameters have been passed that way (and can pass rather more, by your own choice o letter)
Though you pretty much need to be using Python.
If M100 etc really does pass -1 to mean "no value" then that does seem a very poor design choice.
02 Oct 2019 08:39 #146865
by pl7i92
as you aready need a main ngc to get your stuff cordinated
you can do
#5 = 105
o <[#5+6]> call
so you can decide on the main decision ngc on if then or all logic or,and what you want to call
like if we got a parameter then call m100 Parameter1
else if parameter eq 2
call M100 P1 p2
else call M100
there are many easy ways to decide
you can do
#5 = 105
o <[#5+6]> call
call M100 P1 p2
else call M100
17 Nov 2019 17:08 #150530
by amiba
I am new to this and do not really understand where i do need that ngc and how does it work and I did not use python because I do not really know it as well. I am able to use C and a bit C++ but this are old abilities - not trained ones.
I do understand to write a bash or dash script and it was working with a script so I did the script. Until now I could manage it without the real need of knowing if there is a parameter because it was only for things where the -1.0 isn't possible as a parameter but I know this will change soon.
So I would like to understand how the #5 = 105 is to understand as I understand that o will call a subroutine. But I am not sure.
I am glad to watch the machine working and I got all dependencies included.
Time to create page: 0.145 seconds
