X Axis Travel Accuracy
- Jason Arnold
20 Oct 2019 02:07 #148385
by Jason Arnold
X Axis Travel Accuracy was created by Jason Arnold
Hi Guys,
I've searched the forum for a solution but failed to find something relevant to my problem. So a new topic it is.
I've had an issue for some time and have been able to live with it but curiosity has got the better of me and I want to get to the bottom of the problem.
What is the problem: The accuracy of my X axis is in question. I have X setup as the axis moving the spindle left to right and the Y axis is the gantry. See the picture. If I manually command the machine to move X 6" it will always move to within ~1/32" under 6". Move it back to 0 and it comes back exactly to where it started. The movement is very consistent and repeatable! The Y axis which is the gantry will move exactly from 0 to 6". Mmmmm. Scratch ones head...
Some info on the machine:
X & Y axis are rack & pinion drive with Nema 23 steppers. These items were purchased from CNC Routerparts as a kit.
The X axis has one stepper whereas the gantry (Y axis) has two steppers.
The CNC router parts R&P system uses belt reduction with 3:1 ratio. The pinion is a 1" PCD and the rack is 20 teeth/inch.
The driver is a Gecko G540.
What have I done to narrow the problem down?
1. First thing I tried was checking the X axis drive trim on the G540. It was in the sweet spot and no accuracy improvement or change at other trim settings.
2. Swapped one stepper from the Y axis to the X axis. No change in accuracy.
3. Swapped the X cable from the G540 to the Y axis and manually moved the Y axis from 0 to 6". Same result of being about 1/32" short of 6".
4. Checked the X axis for any binding or slop. There is no binding and with R&P no discernible slop.
So from the above checks, I think I have eliminated the G540 and Stepper motors. The X axis repeatably moves as instructed only that it's less than it should be.
Any ideas or suggestions?
Cheers,
Jason.
Cheers,
Jason.
- Mike_Eitel
- Thank you received: 185
20 Oct 2019 12:38 #148406
by Mike_Eitel
Replied by Mike_Eitel on topic X Axis Travel Accuracy
You have to adapt your scale value.
20 Oct 2019 16:32 #148415
by pl7i92
Replied by pl7i92 on topic X Axis Travel Accuracy
- Jason Arnold
20 Oct 2019 19:00 #148420
by Jason Arnold
Replied by Jason Arnold on topic X Axis Travel Accuracy
Hi Mike,
Thank you for your reply.
The X axis is setup the same as the Y. Both axis use the same rack and pinion systems with the only difference being that the Y axis has two racks and drives.
Would it be normal to need a different scale on the X axis?
Cheers,
Jason.
Cheers,
Jason.
- Jason Arnold
20 Oct 2019 19:07 #148421
by Jason Arnold
Hi Pl7i92,
The rack and pinion drive is made by CNC router parts. www.cncrouterparts.com/standard-rack-and...ve-nema-23-p-50.html
Here are the settings they suggest for their system:
MACH Settings for R&P:
The R&P system is based on a pinion with a 1" pitch circle. The total linear distance traveled per revolution of the pinion is thus 3.14159". With the 3:1 reduction, this means that the distance traveled per motor revolution is 3.14159 / 3, or 1.0472". If you have a stepper with 200 steps per revolution, this means you have 200 / 1.0472" = 190.9861 steps per inch, or 0.005236" per step. With 10x microstepping, you would have 1909.861 steps per inch, or 0.0005236" per step. For the optional 3/8" pulley, this number changes to 1736.237, as the motor pulley is slightly larger.
The G540 is set to 10x microstepping.
The pinion is held into the rack with a spring which has a turnbuckle on it so tension can be adjusted. I’ve tried different tensions with no change in accuracy.
Cheers,
Jason.
Cheers,
Jason.
- Jason Arnold
20 Oct 2019 20:14 #148427
by Jason Arnold
Mike,
When you say adapt your scale do you mean adjust the "lead screw" pitch parameter in stepconfig wizard?
Cheers,
Jason.
Cheers,
Jason.
- Mike_Eitel
20 Oct 2019 21:01 #148433
by Mike_Eitel
Pl7i92 has rosen a good point. Is the x axis independent from travel distance? I gues that happens.
If yes, you have to look for backlash. For this you should read
linuxcnc.org/docs/2.7/html/config/ini-config.html chapter 2.11.......
BACKLASH = 0.0000 - Backlash is in machine units. Backlash compensation can be used to make..........
If it is distance related then you have to do scaling. But sorry, I do only direct editing in the hal file.
SCALE = 1909.8 is your candidate to modify in [AXIS-0]
Good luck
Mike
Good luck
Mike
- Jason Arnold
20 Oct 2019 21:32 #148434
by Jason Arnold
Hi Mike,
The problem is distance related. If I manually tell the X axis to move 6" it only moves 5" and 31/32". It does that every time too.
I can't feel or see any backlash in this R&P system. With the machine powered up and a dial indicator on the axis the machine holds very solid when I attempt to move the X axis. I need to check the scale of the dial but I'm sure it only moves the needle +/- 0.001"
I'll have a play around with the scale but it does my head in a little why the Y axis is bang on in distance travelled with identical settings and R&P system.
Cheers,
Jason.
Cheers,
Jason.
21 Oct 2019 02:32 #148438
by Leon82
Replied by Leon82 on topic X Axis Travel Accuracy
Could you have accidentally been shipped a metric unit?
5mm and 3/16 are close enough by eye but only get noticed with an indicator untill you get into long distances
- Jason Arnold
21 Oct 2019 02:51 #148439
by Jason Arnold
They only have two options and both are imperial. 1/4" (20 Teeth pinion) and 3/8" (22 teeth pinion).
When I swapped the steppers it was just the motor and small pulley on the motor. Not the big pulley with pinion.
Cheers,
Jason.
Cheers,
Jason.
Time to create page: 1.463 seconds
