Problem connecting 7i80db to 7i76
12 Dec 2019 14:22 #152533
by Ameone
Problem connecting 7i80db to 7i76 was created by Ameone
Hi everyone,
I am trying to interface a mesa 7i80db (the motherboard) with a 7i76 (the daughtercard). The 7i80db communicates with linuxCNC through ethernet connection. Currently, I'm trying to see if the communication works correctly, however LinuxCNC seems to recognize only the 7i80db but not the 7i76. The steps I've tried are:
Do you have any idea on what might be the problem. Thank you in advance.
halrun
halcmd: loadrt hostmot2
halcmd: loadrt hm2_eth board_ip=192.168.1.121
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 192.168.1.121: Hardware address: 00:60:1b:10:00:5d
hm2_eth: discovered 7I80DB-16
hm2/hm2_7i80.0: Smart Serial Firmware Version 43
hm2/hm2_7i80.0: 68 I/O Pins used:
hm2/hm2_7i80.0: IO Pin 000 (J2-01): StepGen #0, pin Direction (Output)
hm2/hm2_7i80.0: IO Pin 001 (J2-14): StepGen #0, pin Step (Output)
hm2/hm2_7i80.0: IO Pin 067 (J5-13): IOPort
hm2/hm2_7i80.0: registered
sysctl: cannot stat /proc/sys/net/ipv6/conf/eth0:avahi/disable_ipv6: No such file or directory
hm2_eth: ERROR: Failed to execute '/sbin/sysctl -q net.ipv6.conf.eth0:avahi.disable_ipv6=1'
12 Dec 2019 14:52 #152538
Replied by PCW on topic Problem connecting 7i80db to 7i76
The avahi complaint is a network setup issue, not related to the 7I80DB or 7I76
Also for the 7I80DB to recognize the 7I76 requires
1. Proper firmware in the 7I80DB
2. 5V and field power on the 7I76
12 Dec 2019 15:03 #152541
by Ameone
Replied by Ameone on topic Problem connecting 7i80db to 7i76
Thank you very much, the problem was just to power the 7i76 both with 5V and field power.
Time to create page: 0.079 seconds
