Input scale
15 Dec 2019 22:14 #152699
by jeffie-3
Input scale was created by jeffie-3
I have been trying to figure out the input scale.
This is what I have.
2048 steps on the encoder. 5 tpi on the ball screw. two pulleys 12 tooth to 24 tooth. X and Y
2000 steps on the encoder. 5 tpi on the ball screw. two pulleys 10 tooth to 18 tooth Z
Any help would be great.
Thanks,
Jeff
Thanks,
Jeff
15 Dec 2019 23:41 - 15 Dec 2019 23:42 #152700
Replied by PCW on topic Input scale
1. 2048*5*24/12
2. 2000*5*18/10
Assuming:
1. 2048 and 2000 are counts per turn (if they are encoder PPR the numbers above must be multipled by 4)
2. The small pulleys are on the motor
3. Machine units are inches
2. 2000*5*18/10
Assuming:
Last edit: 15 Dec 2019 23:42 by PCW.
The following user(s) said Thank You: jeffie-3
15 Dec 2019 23:58 - 15 Dec 2019 23:59 #152702
by jeffie-3
Replied by jeffie-3 on topic Input scale
Thank you so much.I see the error. I was dividing 12 by 24. Not 24 by 12. Yes the smaller pulley is on the motor.
Thank you...
1. Yes but will double check
2. Yes.
3. Yes.
Thank you...
2. Yes.
3. Yes.
Last edit: 15 Dec 2019 23:59 by jeffie-3.
Time to create page: 0.064 seconds
