Motor Resonance
30 Dec 2019 23:00 #153572
by CNC32
Motor Resonance was created by CNC32
I have a mesa 7i96 and I am using clearpath servo motors which provide no singles back to the 7i96. But anyway when I am testing the motors I move the axis and then stop it and it starts to resonate. I have previously used Mach4 and I did not have this problem. When I looked at the clearpath diagnostics software I noticed that when I moved the axis and stoped the axis the direction signal was fluctuating and the step single was fluttering on and off. It is almost like Linuxcnc is trying to give the motors feedback when the clearpath servo motors already provide there own feedback. Some suggestions would be greatly appreciated.
30 Dec 2019 23:03 #153574
Replied by cmorley on topic Motor Resonance
please post your config files. probably need to adjust your PID values a bit.
Chris
Chris
- Thank you received: 5957
30 Dec 2019 23:04 #153575
Replied by tommylight on topic Motor Resonance
In the hal file, check if you have something like " .........maxerror 0.5 " or similar, delete all the line containing that.
It might also be from interferences from unshielded cables.
30 Dec 2019 23:19 #153577
by CNC32
Replied by CNC32 on topic Motor Resonance
I have attached my config files. I searched the base_config.hall for maxerror and there are 6 instances that all say
step pid.x.maxerror .0005
30 Dec 2019 23:27 #153579
Or just put # in front of those lines, save and restart Linuxcnc.
Delete those lines and the lines above them. something with "previous error......."I have attached my config files. I searched the base_config.hall for maxerror and there are 6 instances that all say
30 Dec 2019 23:54 #153581
by CNC32
Thakyou tommylight for the help!
I have just edited that hal file and commented them out with a # in front of the lines for exampleWhen I go to run linuxCNC I get an error message saying
I have reverted back to the original hal file.
I have included the modified hal file here
#setp pid.X.error-previous-target true
#setp pid.X.maxerror .0005
./Base_config.hal:1: Unknown command ' '
2373
31 Dec 2019 05:00 #153585
That error says you have something wrong on line 1 of the hal file, everything else looks ok.
31 Dec 2019 16:25 #153612
Replied by PCW on topic Motor Resonance
You need these lines:
setp pid.N.error-previous-target true
31 Dec 2019 16:51 #153614
Thank you.
Sorry, i thought that should also go, was not sure though.You need these lines:
Thank you.
31 Dec 2019 17:18 #153617
The reason the step/dir output is dithering is because you have a P term of 10000
This should normally be 1/servo thread period = 1000
