Speed limitation close to software limit by traj planner
15 Jan 2020 00:56 #154870
by Nico2017
Speed limitation close to software limit by traj planner was created by Nico2017
Hi all,
I just want to confirm that the traj planner decreases the speed before reaching a software limit defined in the .ini file as Max or Min limits of a joint or axis. So if you jog manually towards a soft limit, it ramp down the vel cmd instead of going from the jog speed to 0 at the software limit location.
I did some test and it seems to be the case, the traj planner ramping down the speed, but I cannot remember why I use to think it was not the case. Maybe it was not the case in the past.
If someone could confirm this, that would be great.
Thank you
Nicolas
Thank you
Nicolas
15 Jan 2020 01:02 #154871
by Leon82
Replied by Leon82 on topic Speed limitation close to software limit by traj planner
My speeds are about 110 or 120ipm in the ini and it always stops at .01 past the software limit's.
I haven't really tested it thoroughly, but I would assume it will use your acceleration setting to slow down at the limit
15 Jan 2020 01:06 #154875
Replied by andypugh on topic Speed limitation close to software limit by traj planner
A keyboard jog is actually performed as a linear move to the soft limit.
Then, when you release, the move is aborted.
So the move will always stop smoothly and within limits at the soft limit.
15 Jan 2020 01:14 #154877
by Shu
I experienced that on some machines. If I remember correctly they were all closed loop. Are you running servos? A slight overshoot might be the culprit.
Replied by Shu on topic Speed limitation close to software limit by traj planner
15 Jan 2020 01:18 #154878
by Leon82
Steppers.
There is probably a parameter for acceptable overshoot. It has never gone past it.
Even in a fanuc you can set the distance past
15 Jan 2020 04:18 #154888
by Nico2017
Replied by Nico2017 on topic Speed limitation close to software limit by traj planner
I am using servos in position control so I would expect the machine to decelerate smoothly then get bang on the soft limit.
Thank you for your answers.
Nicolas
Nicolas
23 Jan 2020 02:03 #155487
by Nico2017
Hi all,
regarding this topic,I obverse a different behaviour regarding if the motor is homed or not.
If it is homed, the axis min position limits the motion. If it is not homed, the joint min position does not seem to be effective.
Any idea why?
Thank you,
Nicolas
Any idea why?
Thank you,
Nicolas
- Thank you received: 5959
23 Jan 2020 21:52 #155578
Replied by tommylight on topic Speed limitation close to software limit by traj planner
That is normal.
The machine should not be used without being homed first.
The following user(s) said Thank You: Nico2017
23 Jan 2020 22:18 #155581
by Nico2017
ok, that sounds perfectly normal. I am just wondering then why do you define min and max limit for the joints in the ini file?
Is it if the hard limit switch is triggered to get a value for the machine position, or is it for display reason of the machine limits in gremlin or axis?
Thank you,
Nicolas
Thank you,
Nicolas
23 Jan 2020 22:51 #155589
by Leon82
The hard limits are to prevent machine damage from a faulty encoder or a large amount of lost steps or slippage of the coupling.
Ideally you would set them a little after home and min limit.
so in a perfect world you will never hit your hard limit switches only software limit
Time to create page: 0.716 seconds
