Parallel port issues
- drew_hamilton
18 Jan 2020 19:03 #155108
by drew_hamilton
Parallel port issues was created by drew_hamilton
Hi folks,
I am hesitant to post, as I'm sure my question is quite remedial, but I am at a loss.
Background:
I am "renovating" an old Precix CNC to run off of LinuxCNC. I intend to use the original DG2S-08020 Servo Drives (cncdrive.com). After some fussing and a bit of tuning, I've managed to run all three axes from a Teensy 3.6 running the TeensyStep library just to make sure the encoders and drives all work. I'm on something of a schedule, so I'd like to start by keeping things dirt simple, and add complexity later if I find I need it. I have a dual boot Windows 10 / Debian system. I have tested the output signal from Windows and am getting a 0VDC and +5VDC signal when I toggle pins using a parallel port tester program.
Problem:
I am now attempting to get LinuxCNC to work as the motion controller. I have a C83-Optoisolator Board on the way from CNC4PC, but for now, my intent is to just get LinuxCNC outputting a measurable step/direction signal through the StepConf "Axis Test" feature. I set pin 3 to be the x-axis DIR signal. My first test is showing +5VDC (more like +4, really) coming off the output pins no matter what I am doing (measuring with a multimeter: negative to pin 24, positive to pin 3). I also tried the Parallel Port Tester (ptest.hal), and got the same result. It never seems to go "low".
I fear my question may be very naive, so please forgive my ignorance. I've included as much additional information as possible, so I can at least claim to be a good question-asker. Any help will be much appreciated.
Additional Information:
Parallel Port Card: PCI-e x1 Card: SY-PEX10008 (others have apparently used this successfuly with LinuxCNC):
-http://www.sybausa.com/index.php?route=product/product&product_id=143&search=SY-PEX10008
lspci -v:
02:00.2 Parallel controller: MosChip Semiconductor Technology Ltd. PCIe 9912 Multi-I/O Controller (prog-if 03 [IEEE1284])
Subsystem: Device a000:2000
Flags: fast devsel, IRQ 16
I/O ports at e010 [disabled]
I/O ports at e000 [disabled]
[virtual] Memory at f7d01000 (32-bit, non-prefetchable) [size=4K]
[virtual] Memory at f7d00000 (32-bit, non-prefetchable) [size=4K]
Capabilities: <access denied>
Kernel driver in use: parport_serial
Kernel modules: parport_serial
Linux Kernel:
uname -r: 4.9.0.8-rt-amd64
uname -a: Linux Debian 4.9.0.8-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u5 (x86_64 GNU/Linux)
StepConf settings:
ParPort Base Address: e010 (I also tried 0xe010)
Background:
Problem:
lspci -v:
Linux Kernel:
StepConf settings:
- drew_hamilton
18 Jan 2020 20:17 #155110
by drew_hamilton
Replied by drew_hamilton on topic Parallel port issues
As careful as I was to search the forums for a solution to this problem before I posted. I did not even notice the line from lspci that said "[disabled]" after I/O ports at e010 and e000.
Checking back to see if anyone had solved my problem for me, I re-read my own post, and noticed this. The solution to my problem, and I don't quite understand it. Is to run the following command:
echo 1 | sudo dd of=enable
The Parallel Port Tester is now generating a signal when I toggle the pins.
I found this at the following link: emc-users.narkive.com/5K2fpCJR/netmos-98...m-i-o-ports-disabled
Now that I have solved my own problem, I invite any of the senior boarders here to explain what I have just done in plain English.
The following user(s) said Thank You: jody0048
- Thank you received: 5959
18 Jan 2020 20:59 #155112
Replied by tommylight on topic Parallel port issues
That will write a 1 to the "enable" file, though the use of dd is starnge but it should work.
19 Jan 2020 20:38 #155191
The email thread explains that as a way to have sudo do the write, rather than than do the echo.
Replied by andypugh on topic Parallel port issues
19 Jan 2020 20:40 #155193
I am in awe of your Google-fu. How on earth did you manage to find that ancient email thread?
Have you tried looking in the BIOS to see if there is a way to enable the port there?
- drew_hamilton
19 Jan 2020 21:00 #155197
by drew_hamilton
Yeah, 11 years definitely qualifies as ancient. I did check the BIOS, actually. Nothing there. Just ways to enable/disable regular Serial ports.
Time to create page: 0.151 seconds
