Debounce and Base-Thread Help Needed
- Mr. Technical
23 Jan 2020 18:50 - 23 Jan 2020 18:52 #155565
by Mr. Technical
Debounce and Base-Thread Help Needed was created by Mr. Technical
Hi Guys,
I recently installed a touch plate on an older LinuxCNC router installation and have tested it. While it works fine sometimes, it often throws a message about a jog move with probe input triggered. I chalk that up to needing a debounce function, which I am trying to get working.
I added the following to the custom.hal file:
# Include your custom HAL commands here
# This file will not be overwritten when you run PNCconf again
#added 1-22-20
#add this to custom.hal for probe debouncing
#change delay and pin number to fit your needs.
loadrt debounce cfg=1
setp debounce.0.delay 300
addf debounce.0 base-thread
net debounce-probe-in debounce.0.0.in<=hm2_5i25.0.7i76.0.0.input-04-not
net probe-in debounce.0.0.out=>motion.probe-input
#end of probe debouncing.
And added this to the M22-R6Probe.hal file:
# ---probe signal---
#remove the following two lines from (your machine).hal to
#make debounce fix added to custom.hal file work.
#This essentially breaks the original nets in the next two lines
#so they can be reconnected to the debounce function.
#net probe-in => motion.probe-input
#net probe-in => hm2_5i25.0.7i76.0.0.input-04-not
# on 1-19-20,added "-not" in previous line to invert probe-in signal due to adding 4.7K pull up resistor to circuit.)
# tool is grounded, and plate is tied to 24VDC through 4.7k resistor at input 04)
When I try to start LinuxCNC after those changes, I get the following debug message:
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
HAL: ERROR: function 'debounce.0' not found
custom.hal:15: addf failed
10694
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
I've attached the original files below for reference. Does anyone see what is wrong with how I'm trying to do this?
I suspect that the base-thread function is not loading properly, but don't know why.
All help is greatly appreciated.
Mr. Technical
#added 1-22-20
10694
Mr. Technical
Last edit: 23 Jan 2020 18:52 by Mr. Technical.
23 Jan 2020 20:47 #155571
Replied by PCW on topic Debounce and Base-Thread Help Needed
With Mesa cards a base thread is not normally used.
You could use debounce with an appropriate number
of servo thread periods.
- Mr. Technical
23 Jan 2020 22:42 #155585
by Mr. Technical
Replied by Mr. Technical on topic Debounce and Base-Thread Help Needed
Thanks for the info.
So, instead of: addf debounce.0 base-thread
I would use: addf debounce.0 servo-thread
What is typically a good delay value to use for debouncing a touch plate with servo-thread?
That is, what would I enter in this line copied from above?
Thanks,
Mr. Technical
Thanks,
Mr. Technical
24 Jan 2020 01:13 #155609
You might try 3 to 10 (3 to 10 ms at a 1 ms servo thread)
26 Jan 2020 12:31 #155798
by bbsr_5a
Replied by bbsr_5a on topic Debounce and Base-Thread Help Needed
Dont use to many
SPACE Lines and also Comment lines #
from 2.8 update to 2.9 id id run in Problems on this issue
someone told me this
i removed this lines to a min at 2lines to the next and Wonders disapeard
Remember the planer does run to this files on regular bases this might interfear the system at Speed cuting
26 Jan 2020 13:06 #155805
by Clive S
Is this true? As I like to add add a few spaces and ### In my files as I find then easier to read.
Replied by Clive S on topic Debounce and Base-Thread Help Needed
Dont use to many
- Thank you received: 5959
26 Jan 2020 21:02 #155853
############### EDIT BELOW THIS LINE for 7i96 ############################
# Change the pins to corespond to inputs from THC or BOB for UP and DOWN signals
# For negative inputs use the omited part
#net MoveDown hm2_7i96.0.gpio.034.in => or2.0.in0
#net MoveUp hm2_7i96.0.gpio.035.in => or2.0.in1 mux2.1.sel
# Change the pins to corespond to Z-Home limit swith and ARCOK input from THC or BOB
#net FloatSwitch hm2_7i96.0.gpio.036.in => or2.1.in1 and2.4.in0 and2.5.in1 and2.6.in1
#net ArcOK hm2_7i96.0.gpio.037.in => or2.4.in1 xor2.1.in1 oneshot.2.in
# Change the pin number to corespond to where your "spindle on" or relay is connected for starting the torch.
#net TorchOn => and2.3.out hm2_7i96.0.gpio.038.out oneshot.1.in not.2.in
################################ EOF #####################################
############### EDIT BELOW THIS LINE for 7i76E ############################
#net MoveDown hm2_7i76e.0.7i76.0.0.input-00 => or2.0.in0
#net MoveUp hm2_7i76e.0.7i76.0.0.input-01 => or2.0.in1 mux2.1.sel
#net FloatSwitch hm2_7i76e.0.7i76.0.0.input-02 => or2.1.in1 and2.4.in0 and2.5.in1 and2.6.in1
#net ArcOK hm2_7i76e.0.7i76.0.0.input-03 => or2.4.in1 xor2.1.in1 oneshot.2.in
#net TorchOn => and2.3.out hm2_7i76e.0.7i76.0.0.output-00 oneshot.1.in not.2.in
############### EDIT BELOW THIS LINE for 7i77 ############################
net MoveDown torchud.move-down => or2.0.in0
net MoveUp torchud.move-up => or2.0.in1 mux2.1.sel
net FloatSwitch hm2_5i25.0.7i77.0.0.input-02 => or2.1.in1 and2.4.in0 and2.5.in1 and2.6.in1
net ArcOK torchud.arc-ok => or2.4.in1 xor2.1.in1 oneshot.2.in
net TorchOn => and2.3.out hm2_5i25.0.7i77.0.0.output-00 oneshot.1.in not.2.in
Replied by tommylight on topic Debounce and Base-Thread Help Needed
This is the IO.hal file on some of my configs, no issues.
Dont use to many
26 Jan 2020 22:02 #155863
by Clive S
Exactly
05 Feb 2020 13:11 #156586
This is not true. The HAL file is parsed exactly once at system startup. It is used to move all the HAL pin pointers to the right places in the shared memory section. From that point on the HAL file is never used again.
Replied by andypugh on topic Debounce and Base-Thread Help Needed
Time to create page: 0.092 seconds
