Dual PSU On XYYZ Router
- Project_Hopeless
- Topic Author
- Thank you received: 9
03 Apr 2020 21:37 #162611
by Project_Hopeless
Dual PSU On XYYZ Router was created by Project_Hopeless
I'm finalizing my control panel wiring. Full disclosure, when I have time to think, I can over think it.
So currently I have one PSU powering the two Y motors and one powering the X and Z motors.
There is no need to split the Y axis up across the two supplies is there? Maybe balance the load a little across the two PSU?
03 Apr 2020 21:50 #162612
Replied by rodw on topic Dual PSU On XYYZ Router
You'll be fine. I only use 1 PSU for all 4 motors. (Assuming correctly sized PSU's)
09 Apr 2020 13:32 #163344
Replied by andypugh on topic Dual PSU On XYYZ Router
There may be a trade-off between load balancing and fault behaviour.
With your current arrangement, if the Y PSU stops then both motors stop.
This is probably a good thing.
Time to create page: 0.134 seconds
