Pendant interfacing
12 Feb 2023 12:27 #264351 by looping
Pendant interfacing was created by looping
Hello
I wanted to add a pendant to my cnc.
I basicaly looked at xhc series but then decided that I would rather build something cool and flexible on my own . Of course, I will waste a lot of time, rather than taking some of the shelf.
I 'm using an NanoESP32-S2 and  3.5 Nextion display.
Currently for the USB communication, I emulate a xhc so I use xhc-hb04 standard HAL module on linuxcnc side.
Beside the over complicated USB protocol, I found some "limitations" : I can display 6 axis (in G5x coords) or 3 axis in G5x + Machine Coords.
So XYZA in G5x + Machine Coords is not possible.
Do you known if there is some alternative to the xhc-hb04 HAL module ?
16 Feb 2023 20:28 #264644 by looping
Replied by looping on topic Pendant interfacing
Anyway, I will try to have something working with this, regardless the A axis. Futur will tell if À axis worth the time modifying the hal module.
The following user(s) said Thank You: CtodLinuxcnc
16 Feb 2023 23:19 - 16 Feb 2023 23:20 #264668 by rodw
Replied by rodw on topic Pendant interfacing
You could look at the Pokeys USB board as it has a linuxcnc driver. I've tested and it works (slowly) they say 15 Hz for MPG's
Last edit: 16 Feb 2023 23:20 by rodw.
28 Feb 2023 19:30 - 28 Feb 2023 19:35 #265602 by looping
On usb paquet I received from xhc-hb04, it seems that randomly feedrate_ovr and sspeed_ovr are corrupted :
whb04_out_data
magic:0xfdfe
day:12
pos[0]:0,0
pos[1]:0,0
pos[2]:50,0
pos[3]:0,0
pos[4]:0,0
pos[5]:0,0
feedrate_ovr:100
sspeed_ovr:100
feedrate:0
sspeed:0
step_mul:1
state:0
setSpeedOvr:0 old:100
whb04_out_data
magic:0xfdfe
day:12
pos[0]:0,0
pos[1]:0,0
pos[2]:50,0
pos[3]:0,0
pos[4]:0,0
pos[5]:0,0
feedrate_ovr:356
sspeed_ovr:0
feedrate:0
sspeed:0
step_mul:1
state:0
whb04_out_data
magic:0xfdfe
day:12
pos[0]:0,0
pos[1]:0,0
pos[2]:50,0
pos[3]:0,0
pos[4]:0,0
pos[5]:0,0
feedrate_ovr:100
sspeed_ovr:100
feedrate:0
sspeed:0
step_mul:1
state:0
The error is always the same values (356, 0)
I checked my firmware but I can't find anything wrong on my side.
export LIBUSB_DEBUG=4 didn't help me.
On your genuine pendant do you notice some kind of glitches ?
Last edit: 28 Feb 2023 19:35 by looping. Reason: typo
05 Mar 2023 11:44 #265907 by looping
Wireshark did. And packets emited by xhc-hb04 are not corrupted.
So the bug is on the Esp side : in my code or in the USB framework :(
05 Mar 2023 12:37 - 05 Mar 2023 12:44 #265909 by looping
Something weird : it seems to occur only on packet #4 and #5
Last edit: 05 Mar 2023 12:44 by looping.
05 Mar 2023 18:20 - 05 Mar 2023 18:41 #265932 by looping
It also occurs on the last bloc.
I'm afraid it's from the USB framework:
After processing a bloc of 7 bytes, I tried to fill it with the index of the processed bloc. On the next USB callback for new block, I still have the data I wrote on the previous step. So it's clear the content provided by the callback has not been updated.
Recv: fe fd 0c 0a 00 00 00 80 0a 00 00 00 14 00 07 07 07 07 07 07 07 00 64 00 00 00 00 00 15 15 15 15 15 15 15 01 00
Recv: fe fd 0c 0a 00 00 00 14 00 00 00 14 00 00 80 0a 00 00 00 14 00 00 00 14 00 00 80 64 00 64 00 00 00 00 00 01 00
Recv: fe fd 0c 0a 00 00 00 14 00 00 00 14 00 00 80 0a 00 00 00 14 00 00 00 14 00 00 80 64 01 00 00 00 00 00 00 1c 1c
Last edit: 05 Mar 2023 18:41 by looping.
05 Mar 2023 19:00 #265937 by looping
Workaround :
After processing a bloc of 7 bytes, filling it  0xFF.
On the next callback if new block is full of 0xFF, dropping all
19:48:28.731 > Blank found on offset 0x15, droping
19:48:42.671 > Blank found on offset 0x2A, droping
19:49:10.199 > Blank found on offset 0x2A, droping
19:49:17.326 > Blank found on offset 0x23, droping
19:49:20.882 > Blank found on offset 0x1C, droping
19:49:21.689 > Blank found on offset 0x23, droping
19:50:32.587 > Blank found on offset 0x2A, droping
19:51:00.062 > Blank found on offset 0x15, droping
19:51:06.886 > Blank found on offset 0x23, droping
19:52:05.378 > Blank found on offset 0x1C, droping
19:52:12.478 > Blank found on offset 0x2A, droping
19:53:13.445 > Blank found on offset 0x1C, droping
19:53:25.142 > Blank found on offset 0x1C, droping
19:54:03.582 > Blank found on offset 0x2A, droping
19:54:09.337 > Blank found on offset 0x15, droping
19:54:39.046 > Blank found on offset 0x15, droping
Info: XHC-HB04 sends a full message every ~7ms
06 Mar 2023 18:47 #265967 by looping
I just discover that this is not needed : when the A axis is selected, it's wc and mc are feeded to the pendant using X axis values
19 Mar 2023 15:31 #267087 by looping
It is alive :
The PCB was designed for Arduino Pro Micro, so since I'm now using a Esp32S2 I have to use a bread board. I aslo added some level shifter to adapt 5V hall encoders to Esp32 3.3V I/O.
The PCB and the case will be redesign
The following user(s) said Thank You: smc.collins
Time to create page: 0.184 seconds
