Pendant interfacing
- CtodLinuxcnc
12 Apr 2023 00:05 #268858
by CtodLinuxcnc
Replied by CtodLinuxcnc on topic Pendant interfacing
Just chiming in to say I appreciate you posting this and may try this for myself later down the road
25 Apr 2023 12:29 #269852
by looping
Replied by looping on topic Pendant interfacing
I re-printed the case because it was originaly should be fitted with a arduino Pro Micro. But I now switched to an Esp32-S2 so I need redo the PCB.
The wheel and the 2 selectors were too close, so I also make the case a little bit bigger.
I'm also thinking about adding a security feature to ensure the operator is actually holding the device. I will order some MLX90614ESF to test if I can detect the hand on the back of the device and the reliability.
The following user(s) said Thank You: CtodLinuxcnc
- daonixinliqu
29 Jun 2023 04:37 #274432
by daonixinliqu
Replied by daonixinliqu on topic Pendant interfacing
I have a hand wheel, I want to modify him, there are matrix keys, there are hand wheels, I know nothing about the code can share your code
01 Jul 2023 13:12 #274599
by looping
- daonixinliqu
02 Jul 2023 03:23 #274617
by daonixinliqu
Thank you for your reply. I have a MEGA2560
02 Jul 2023 11:45 #274633
by looping
My code is still under dev and is not proven to work correctly with LinuxCnc yet.
I used this as base : bitbucket.org/moonglow/openxhc.git
So it seems that you will have to make a portage anyway.
- daonixinliqu
03 Jul 2023 00:22 #274669
by daonixinliqu
Thanks for the link
Time to create page: 0.109 seconds
