Mesa 7C80 more apropiate firmware for lathe
- Baldorcete
11 Mar 2023 11:28 #266395
by Baldorcete
Mesa 7C80 more apropiate firmware for lathe was created by Baldorcete
HI all.
I'm an absolute beginer to linuxCNC, so please, be a little patient with me.
I have several questions, buy I will divide them in diferent threads to keep it clean and organized.
I want to CNC a minilathe. The harware is:
Raspberry Pi 4 with linuxCNC 2.8 ( linuxcnc.org/docs/html/getting-started/getting-linuxcnc.html )
Mesa 7C80
CL86T v4 Stepper controller for Z axis: (www.omc-stepperonline.com/index.php?rout...)%20manual%20(1).pdf )
ISV57T-180 stepper for X axis ( www.omc-stepperonline.com/download/iSV57T(S).pdf )
I want to use the error signal from both controllers.
generic 1000ppr with index encoder for spindle.
generic VFD for the spindle
Homemade MPG with 100ppr weel, 4 pos switch for speed selection, single NO switch for axis selection.
Currently I have 7C80b firmware loaded on the board. In the mesa download there are a lot of firmwares. What is the better suited firmware for this use?
Best regards
Mesa 7C80
Best regards
11 Mar 2023 17:38 #266419
Replied by PCW on topic Mesa 7C80 more apropiate firmware for lathe
The standard firmware should be fine
Customization for you hardware would be done in the HAL/INI files
The following user(s) said Thank You: Baldorcete
- Baldorcete
11 Mar 2023 18:57 #266425
by Baldorcete
Replied by Baldorcete on topic Mesa 7C80 more apropiate firmware for lathe
Thanks. Since I had to reflash the card via JTAG, I loaded 7C80d.bit, thinking it was the default firmware. Is this right?
11 Mar 2023 19:27 #266427
Yes.
Time to create page: 0.103 seconds
