My Steppers won‘t work
16 Mar 2023 16:34 - 17 Mar 2023 21:24 #266845
by Elias B.
My Steppers won‘t work was created by Elias B.
I am new to this whole CNC Theme and are currently building a my first Machine. I finished my Control Cabinet and did my pcconf.
Now, if I hit the enable button on my gui, i cant move the steppers anymore but if I want to move the motor, nothing happens. I checked my pins multiple times and Config and can‘t figure out where the problem is. Has anyone any Idea?
Last edit: 17 Mar 2023 21:24 by Elias B..
16 Mar 2023 17:48 - 16 Mar 2023 17:53 #266851
Replied by Aciera on topic My Steppers won‘t work
please post the .hal and .ini files from your machine configuration folder.
[edit]
Also are the status leds of your mesa card lit as per the description of page 12 in the manual? :
www.mesanet.com/pdf/parallel/7i76man.pdf
[edit]
Last edit: 16 Mar 2023 17:53 by Aciera.
17 Mar 2023 18:16 #266928
by Elias B.
Replied by Elias B. on topic My Steppers won‘t work
Hi, thank you for your reply. In the attached files there is everything you ask for. Bcs I didn´t found the exact page with the led setup, i attached an image with the leds.
- Thank you received: 5944
17 Mar 2023 18:50 #266931
Replied by tommylight on topic My Steppers won‘t work
@Elias,
Please remove the link from the original post.
Thank you.
Thank you.
17 Mar 2023 19:17 #266935
Replied by PCW on topic My Steppers won‘t work
Are the step drive enables connected?
Note that these are most often DISABLE inputs so disable the drives when active
17 Mar 2023 21:23 #266943
by Elias B.
If I press enable in the programm, the right voltage is applied to enable and the motors is locked.
17 Mar 2023 22:44 #266947
In your ini file, from this
DIRSETUP = 7000
DIRHOLD = 7000
STEPLEN = 3500
STEPSPACE = 3500
to this
DIRSETUP = 20000
DIRHOLD = 20000
STEPLEN = 5000
STEPSPACE = 5000
DIRSETUP = 7000
DIRHOLD = 7000
STEPLEN = 3500
STEPSPACE = 3500
to this
DIRSETUP = 20000
DIRHOLD = 20000
STEPLEN = 5000
STEPSPACE = 5000
18 Mar 2023 13:51 #266999
by Elias B.
Tried, no change at all unfortunately
18 Mar 2023 15:23 #267007
On the Mesa side, remove step- and wire it to GND.
Try one drive.
Just to be sure, do motors lock when LinuxCNC is running and enabled with F2 or Enable button on GUI?
Try one drive.
18 Mar 2023 16:17 #267012
by Elias B.
I wired Step- to GND, no change at all.
And yes, if i press F2/Press the Button, the motor is locked.
Time to create page: 0.356 seconds
