My Steppers won‘t work
18 Mar 2023 18:14 #267020
Replied by PCW on topic My Steppers won‘t work
Do you have 7I76 firmware in the 5I25?
21 Mar 2023 13:25 #267229
by Elias B.
Replied by Elias B. on topic My Steppers won‘t work
As far as i know, yes. Is there an easy way to check this?
- Thank you received: 5944
21 Mar 2023 13:58 #267230
Replied by tommylight on topic My Steppers won‘t work
mesaflash --device 5i25 --readhmid
21 Mar 2023 14:15 #267231
by Elias B.
This is the Output, looks correct
Configuration Name: HOSTMOT2
BoardName : MESA5I25
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
There are 2 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: StepGen
There are 10 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 0 IOPort StepGen 5 Dir/Table2 (Out)
14 1 IOPort StepGen 5 Step/Table1 (Out)
2 2 IOPort StepGen 6 Dir/Table2 (Out)
15 3 IOPort StepGen 6 Step/Table1 (Out)
3 4 IOPort StepGen 7 Dir/Table2 (Out)
16 5 IOPort StepGen 7 Step/Table1 (Out)
4 6 IOPort StepGen 8 Dir/Table2 (Out)
17 7 IOPort StepGen 8 Step/Table1 (Out)
5 8 IOPort StepGen 9 Dir/Table2 (Out)
6 9 IOPort StepGen 9 Step/Table1 (Out)
7 10 IOPort SSerial 0 TXData2 (Out)
8 11 IOPort SSerial 0 RXData2 (In)
9 12 IOPort SSerial 0 TXData3 (Out)
10 13 IOPort SSerial 0 RXData3 (In)
11 14 IOPort QCount 1 Quad-IDX (In)
12 15 IOPort QCount 1 Quad-B (In)
13 16 IOPort QCount 1 Quad-A (In)
IO Connections for P2
1 17 IOPort StepGen 0 Dir/Table2 (Out)
14 18 IOPort StepGen 0 Step/Table1 (Out)
2 19 IOPort StepGen 1 Dir/Table2 (Out)
15 20 IOPort StepGen 1 Step/Table1 (Out)
3 21 IOPort StepGen 2 Dir/Table2 (Out)
16 22 IOPort StepGen 2 Step/Table1 (Out)
4 23 IOPort StepGen 3 Dir/Table2 (Out)
17 24 IOPort StepGen 3 Step/Table1 (Out)
5 25 IOPort StepGen 4 Dir/Table2 (Out)
6 26 IOPort StepGen 4 Step/Table1 (Out)
7 27 IOPort SSerial 0 TXData0 (Out)
8 28 IOPort SSerial 0 RXData0 (In)
9 29 IOPort SSerial 0 TXData1 (Out)
10 30 IOPort SSerial 0 RXData1 (In)
11 31 IOPort QCount 0 Quad-IDX (In)
12 32 IOPort QCount 0 Quad-B (In)
13 33 IOPort QCount 0 Quad-A (In)
21 Mar 2023 15:37 #267235
Seems like it does need firmware for 7i76 to be flashed.
Go to Mesa 5i25 page, there should be firmware for download there, where the PDF manual is.
Find a how to flash Mesa, use the bin file with 5i25 and 7i76 in the name.
Sorry for not helping much, on the phone.
The following user(s) said Thank You: Elias B.
21 Mar 2023 16:51 #267238
If you measure the DIR0+ output to ground, with a voltmeter
does it change when you jog X in both directions?
21 Mar 2023 17:38 - 22 Mar 2023 09:17 #267242
by Elias B.
It works now. Thank you all so much.
The firmware as the problem
Last edit: 22 Mar 2023 09:17 by Elias B..
Time to create page: 0.082 seconds
