7i90hd configuration not start linuxcnc
04 Apr 2023 13:59 #268265
by telmoram
7i90hd configuration not start linuxcnc was created by telmoram
Please help me, don´t start linuxcnc with board 7i90hd, configuration files was created with pncconf wizard,
Attach the file report by linuxcnc.
Thanks.
Thanks.
- Thank you received: 5944
04 Apr 2023 14:42 #268268
Replied by tommylight on topic 7i90hd configuration not start linuxcnc
No file...
04 Apr 2023 23:38 #268299
by telmoram
Replied by telmoram on topic 7i90hd configuration not start linuxcnc
This is the error log file:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.10.0-pre0-1064-geef658e53
Machine configuration directory is '/home/cnc/linuxcnc/configs/7i90hd'
Machine configuration file is '7i90hd.ini'
INIFILE=/home/cnc/linuxcnc/configs/7i90hd/7i90hd.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./7i90hd.hal
hm2_7i90: loading HostMot2 Mesa 7i90 driver version 0.3
hm2: no firmware specified in config modparam! the board had better have firmware configured already, or this won't work
hm2/hm2_7i90.0: Low Level init 0.15
hm2/hm2_7i90.0: 72 I/O Pins used:
hm2/hm2_7i90.0: IO Pin 000 (P1-01): Encoder #1, pin B (Input)
hm2/hm2_7i90.0: IO Pin 001 (P1-03): Encoder #1, pin A (Input)
hm2/hm2_7i90.0: IO Pin 002 (P1-05): Encoder #0, pin B (Input)
hm2/hm2_7i90.0: IO Pin 003 (P1-07): Encoder #0, pin A (Input)
hm2/hm2_7i90.0: IO Pin 004 (P1-09): Encoder #1, pin Index (Input)
hm2/hm2_7i90.0: IO Pin 005 (P1-11): Encoder #0, pin Index (Input)
hm2/hm2_7i90.0: IO Pin 006 (P1-13): PWMGen #1, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i90.0: IO Pin 007 (P1-15): PWMGen #0, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i90.0: IO Pin 008 (P1-17): PWMGen #1, pin Out1 (Dir or Down) (Output)
hm2/hm2_7i90.0: IO Pin 009 (P1-19): PWMGen #0, pin Out1 (Dir or Down) (Output)
hm2/hm2_7i90.0: IO Pin 010 (P1-21): PWMGen #1, pin Not-Enable (Output)
hm2/hm2_7i90.0: IO Pin 011 (P1-23): PWMGen #0, pin Not-Enable (Output)
hm2/hm2_7i90.0: IO Pin 012 (P1-25): Encoder #3, pin B (Input)
hm2/hm2_7i90.0: IO Pin 013 (P1-27): Encoder #3, pin A (Input)
hm2/hm2_7i90.0: IO Pin 014 (P1-29): Encoder #2, pin B (Input)
hm2/hm2_7i90.0: IO Pin 015 (P1-31): Encoder #2, pin A (Input)
hm2/hm2_7i90.0: IO Pin 016 (P1-33): Encoder #3, pin Index (Input)
hm2/hm2_7i90.0: IO Pin 017 (P1-35): Encoder #2, pin Index (Input)
hm2/hm2_7i90.0: IO Pin 018 (P1-37): IOPort
hm2/hm2_7i90.0: IO Pin 019 (P1-39): IOPort
hm2/hm2_7i90.0: IO Pin 020 (P1-41): IOPort
hm2/hm2_7i90.0: IO Pin 021 (P1-43): IOPort
hm2/hm2_7i90.0: IO Pin 022 (P1-45): IOPort
hm2/hm2_7i90.0: IO Pin 023 (P1-47): IOPort
hm2/hm2_7i90.0: IO Pin 024 (P2-01): StepGen #0, pin Step (Output)
hm2/hm2_7i90.0: IO Pin 025 (P2-03): StepGen #0, pin Direction (Output)
hm2/hm2_7i90.0: IO Pin 026 (P2-05): IOPort
hm2/hm2_7i90.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_7i90.0: IO Pin 028 (P2-09): IOPort
hm2/hm2_7i90.0: IO Pin 029 (P2-11): IOPort
hm2/hm2_7i90.0: IO Pin 030 (P2-13): StepGen #1, pin Step (Output)
hm2/hm2_7i90.0: IO Pin 031 (P2-15): StepGen #1, pin Direction (Output)
hm2/hm2_7i90.0: IO Pin 032 (P2-17): IOPort
hm2/hm2_7i90.0: IO Pin 033 (P2-19): IOPort
hm2/hm2_7i90.0: IO Pin 034 (P2-21): IOPort
hm2/hm2_7i90.0: IO Pin 035 (P2-23): IOPort
hm2/hm2_7i90.0: IO Pin 036 (P2-25): StepGen #2, pin Step (Output)
hm2/hm2_7i90.0: IO Pin 037 (P2-27): StepGen #2, pin Direction (Output)
hm2/hm2_7i90.0: IO Pin 038 (P2-29): IOPort
hm2/hm2_7i90.0: IO Pin 039 (P2-31): IOPort
hm2/hm2_7i90.0: IO Pin 040 (P2-33): IOPort
hm2/hm2_7i90.0: IO Pin 041 (P2-35): IOPort
hm2/hm2_7i90.0: IO Pin 042 (P2-37): StepGen #3, pin Step (Output)
hm2/hm2_7i90.0: IO Pin 043 (P2-39): StepGen #3, pin Direction (Output)
hm2/hm2_7i90.0: IO Pin 044 (P2-41): IOPort
hm2/hm2_7i90.0: IO Pin 045 (P2-43): IOPort
hm2/hm2_7i90.0: IO Pin 046 (P2-45): IOPort
hm2/hm2_7i90.0: IO Pin 047 (P2-47): IOPort
hm2/hm2_7i90.0: IO Pin 048 (P3-01): IOPort
hm2/hm2_7i90.0: IO Pin 049 (P3-03): IOPort
hm2/hm2_7i90.0: IO Pin 050 (P3-05): IOPort
hm2/hm2_7i90.0: IO Pin 051 (P3-07): IOPort
hm2/hm2_7i90.0: IO Pin 052 (P3-09): IOPort
hm2/hm2_7i90.0: IO Pin 053 (P3-11): IOPort
hm2/hm2_7i90.0: IO Pin 054 (P3-13): IOPort
hm2/hm2_7i90.0: IO Pin 055 (P3-15): IOPort
hm2/hm2_7i90.0: IO Pin 056 (P3-17): IOPort
hm2/hm2_7i90.0: IO Pin 057 (P3-19): IOPort
hm2/hm2_7i90.0: IO Pin 058 (P3-21): IOPort
hm2/hm2_7i90.0: IO Pin 059 (P3-23): IOPort
hm2/hm2_7i90.0: IO Pin 060 (P3-25): IOPort
hm2/hm2_7i90.0: IO Pin 061 (P3-27): IOPort
hm2/hm2_7i90.0: IO Pin 062 (P3-29): IOPort
hm2/hm2_7i90.0: IO Pin 063 (P3-31): IOPort
hm2/hm2_7i90.0: IO Pin 064 (P3-33): IOPort
hm2/hm2_7i90.0: IO Pin 065 (P3-35): IOPort
hm2/hm2_7i90.0: IO Pin 066 (P3-37): IOPort
hm2/hm2_Shutting down and cleaning up LinuxCNC...
Running HAL shutdown script
7i90.0: IO Pin 067 (P3-39): IOPort
hm2/hm2_7i90.0: IO Pin 068 (P3-41): IOPort
hm2/hm2_7i90.0: IO Pin 069 (P3-43): IOPort
hm2/hm2_7i90.0: IO Pin 070 (P3-45): IOPort
hm2/hm2_7i90.0: IO Pin 071 (P3-47): IOPort
hm2/hm2_7i90.0: registered
hm2_7i90.0: board at (ioaddr=0x0378, ioaddr_hi=0x0000, epp_wide OFF) found
hm2_7i90.0: releasing board
hm2/hm2_7i90.0: unregistered
hm2_7i90: driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
./7i90hd.hal:23: parameter or pin 'hm2_7i90.0.dpll.01.timer-us' not found
3170
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: mar abr 4 08:45:25 -05 2023
UTC Date: mar abr 4 13:45:25 UTC 2023
this program: /usr/bin/linuxcnc_info
uptime: 08:45:25 up 6:36, 1 user, load average: 0,09, 0,10, 0,07
lsb_release -sa: Debian Debian GNU/Linux 10 (buster) 10 buster
linuxcnc: /usr/bin/linuxcnc
pwd: /home/cnc/linuxcnc/configs/7i90hd
USER: cnc
LOGNAME: cnc
HOME: /home/cnc
EDITOR:
VISUAL:
LANGUAGE: es_EC:es
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 1280x720 pixels (339x191 millimeters)
PATH: /usr/bin:/home/cnc/linuxcnc/configs/7i90hd/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: debian
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT RT Debian 4.19.269-1 (2022-12-20)
machine -m: x86_64
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.19.0-23-rt-amd64 root=UUID=176ba136-960f-491d-a51b-f1e30772d14e ro quiet
model name: AMD E1-6010 APU with AMD Radeon R2 Graphics
cores: 2
cpu MHz: 1197.823
parport: 0000-0000 : parport0 0000-0000 : parport0
serial: 0000-0000 : serial
Versions:
gcc: gcc (Debian 8.3.0-6) 8.3.0
python: Python 3.7.3
git: git version 2.20.1
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.10.0-pre0-1064-geef658e53
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /usr/lib/linuxcnc/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
PYTHON: /usr/bin/python3
dpkg -l '*linuxcnc*':
Deseado=desconocido(U)/Instalar/eliminaR/Purgar/retener(H)
| Estado=No/Inst/ficheros-Conf/desempaqUetado/medio-conF/medio-inst(H)/espera-disparo(W)/pendienTe-disparo
|/ Err?=(ninguno)/requiere-Reinst (Estado,Err: mayúsc.=malo)
||/ Nombre Versión Arquitectura Descripción
un linuxcnc <ninguna> <ninguna> (no hay ninguna descripción disponible)
un linuxcnc-dev <ninguna> <ninguna> (no hay ninguna descripción disponible)
un linuxcnc-doc <ninguna> <ninguna> (no hay ninguna descripción disponible)
ii linuxcnc-doc-en 1:2.10.0~pre0.1064.geef658e53 all motion controller for CNC machines and robots (English documentation)
ii linuxcnc-doc-es 1:2.10.0~pre0.1064.geef658e53 all controlador de movimiento para máquinas CNC y robots (Español).
ii linuxcnc-doc-fr 1:2.10.0~pre0.1064.geef658e53 all motion controller for CNC machines and robots (French documentation)
un linuxcnc-sim <ninguna> <ninguna> (no hay ninguna descripción disponible)
un linuxcnc-sim-dev <ninguna> <ninguna> (no hay ninguna descripción disponible)
ii linuxcnc-uspace 1:2.10.0~pre0.1064.geef658e53 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 1:2.10.0~pre0.1064.geef658e53 amd64 PC based motion controller for real-time Linux
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
hm2: unloading
3170
pastebin.com
USER: cnc
LOGNAME: cnc
HOME: /home/cnc
EDITOR:
VISUAL:
LANGUAGE: es_EC:es
TERM: dumb
COLORTERM:
DISPLAY: :0.0
uname items:
nodename -n: debian
machine -m: x86_64
/proc items:
cores: 2
cpu MHz: 1197.823
Versions:
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
RTS: uspace
05 Apr 2023 01:48 #268309
Edit the hal file with a text editor (not with office and not on a windows PC), find the line containing
should be line 23, omit it by adding # in front of the line, save.
Start the config from desktop or however you start it.
05 Apr 2023 11:35 #268330
by telmoram
Thanks, it worked
# setp hm2_7i90.0.dpll.01.timer-us -50
# setp hm2_7i90.0.stepgen.timer-number 1
comment these two lines and it worked, but how do these two lines affect the operation?
05 Apr 2023 11:53 #268332
Not that i am aware of, at least for most of the stuff i used, but i do remember one instance when i needed that using Serial Absolute Encoders on a retrofit.
Time to create page: 0.130 seconds
