Huanyang VFD RS485 error is braking too fast.
08 Apr 2023 02:31 - 08 Apr 2023 19:09 #268578
by sliptonic
Huanyang VFD RS485 error is braking too fast. was created by sliptonic
I have a Huanyang VFD connected to my PC with Usb to RS485 converter. Everything works fine most of the time.
During a tool change, the spindle shuts down and the brake is activated, rather aggressively. About 1 time in 3, the spindle will fail to restart. I have to shutdown linuxcnc and restart it. If I launch from a console, I see a modbus communication error cycling like it lost connection.
If, however, I put a wrench on the spindle brake to keep it from activating too fast and let the spindle slow down a bit, the error never occurs. How can I avoid this error?
My entire configuration is here in the master branch: github.com/sliptonic/millstone
Last edit: 08 Apr 2023 19:09 by sliptonic.
11 Apr 2023 23:07 #268854
Replied by andypugh on topic Huanyang VFD RS485 error is braking too fast.
What controls the spindle brake? Is it an output from the VFD?
Do you have a braking resistor attached?
