Tool touchoff remap M6 hangs
- frayja2002
- Thank you received: 11
15 Apr 2023 01:52 #269048
by frayja2002
Tool touchoff remap M6 hangs was created by frayja2002
Hi there
I am having a bit of trouble with an M6 remap setup.
I have set this up on one machine & everything works as expected.
I have set this up on another with only the obvious i/o & hal changes & when I try to call a T1M6 linuxcnc just hangs & gives no error.
Both configs reference the same M6 & M600 files so I do not believe the problem is there.
I have posted the config files.
If someone has some ideas i would be grateful as I am at a loss.
Alex
Alex
- frayja2002
15 Apr 2023 02:20 #269050
by frayja2002
Replied by frayja2002 on topic Tool touchoff remap M6 hangs
Sorry all
I may have found the problem.
I missed the bit signaling the manual tool change.
is there a way to see what Linuxcnc is waiting for( just for future reference)
This has been a some what frustrating problem to chase.
Anyway here is the corrected file.
- Thank you received: 5944
15 Apr 2023 09:58 #269085
Replied by tommylight on topic Tool touchoff remap M6 hangs
All pins, parameters, etc can be monitored using the included "show hal configuration" from the machine menu.
15 Apr 2023 10:05 #269087
If the iocontrol.0.tool-change pin is connected to hal_manualtoolchange then there is a popup. And if it is connected directly to the iocontrol.0.tool-changed pin then there is no wait. If you leave the pin hanging, then you get the behaviour that you saw, and no clue why until you start looking at HAL pins, and you do need to know what to look at.
This is a configuration-time problem, though, not a use-time problem.
Replied by andypugh on topic Tool touchoff remap M6 hangs
That was my immediate guess...I may have found the problem.
