7i92 and G540 combination?
29 Jul 2023 01:14 #276502
Replied by PCW on topic 7i92 and G540 combination?
So you have no fault light on the G540?
Do the motors have holding torque?
29 Jul 2023 04:46 #276512
by P.J.B.C
Replied by P.J.B.C on topic 7i92 and G540 combination?
No, as i have said they still just spin freely...
29 Jul 2023 13:42 #276524
Did you try disabling the G540's chargepump? (it has a switch for this)
02 Aug 2023 00:32 #276748
by P.J.B.C
yes, I have... I gave it one more go but no luck...
02 Aug 2023 00:54 - 02 Aug 2023 00:54 #276750
OK so if you have the G540 chargepump disabled and the G540 estop input is defeated,
this is a hardware issue with the G540 (no signal from the 7I92 can affect this)
Do you have the current setting resistors installed in the G540 stepper connectors?
Last edit: 02 Aug 2023 00:54 by PCW.
02 Aug 2023 09:32 #276769
by P.J.B.C
Yeah it is funny, like the g540 has an odd logic circuit that is somehow incompatible with the mesa hardware...
That is why i made this thread... i still require any information from others as to if they have had success or not.
As for myself, i am dying to get my project back on the road and need to pursue my back up plan,
which involves the use of the parallel ports on my old motherboard...
I bought a couple of PCI-e adapter cards which claim to be a mcs9901 chip...
do you mind helping me with the driver installation...
- Thank you received: 5979
02 Aug 2023 11:12 #276772
Replied by tommylight on topic 7i92 and G540 combination?
Disconnect the DB25 cable from G540, power on G540 with charge pump set to OFF, put it out of E-stop, motors should lock, test by hand if they can be rotated.
If they do not lock, no Mesa or config will help as that is a G540 issue.
03 Aug 2023 02:28 - 03 Aug 2023 02:31 #276813
by P.J.B.C
OK... You got it... there were still free wheeling...
It must have been that i suffered the drives at some point, and i replaced the motherboard only...
they passed visual inspection only...
Last edit: 03 Aug 2023 02:31 by P.J.B.C.
03 Aug 2023 10:44 #276831
Does G540 still use 4 of G251 drives? Small boards with 8 mosfets on the back?
There should be a manual for it and wiring diagram so can be checked individually out of the board, just find a flat hard drive or flopy cable. Also check the pin to wire numbering for those cables.
05 Aug 2023 04:47 #276969
by P.J.B.C
I've just ordered a single replacement drive and i'll plug it in alone, see if that does it...
But I am not sure anything is wrong with any of the electronics...
Time to create page: 0.105 seconds
