Secure (8) error Won't update
- Routerworks
- Thank you received: 8
05 May 2023 15:53 #270735
by Routerworks
Secure (8) error Won't update was created by Routerworks
This get tiring. Now when I use sudo apt-get update here is what I get:
$ sudo apt-get update
Ign:1 cdrom://[Debian GNU/Linux 10 _Buster_ - Official Snapshot amd64 LIVE/INSTALL Binary 20210706-21:57] buster InRelease
Err:2 cdrom://[Debian GNU/Linux 10 _Buster_ - Official Snapshot amd64 LIVE/INSTALL Binary 20210706-21:57] buster Release
Please use apt-cdrom to make this CD-ROM recognized by APT. apt-get update cannot be used to add new CD-ROMs
Hit:3 www.linuxcnc.org buster InRelease
Reading package lists... Done
E: The repository 'cdrom://[Debian GNU/Linux 10 _Buster_ - Official Snapshot amd64 LIVE/INSTALL Binary 20210706-21:57] buster Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Also no "lsusb" response or "ipconfig"
Can't download these utilities because it won't let me get to Github.
Would appreciate help understanding this.
05 May 2023 20:13 #270749
Replied by rodw on topic Secure (8) error Won't update
Ensure you have an internet connection
edit /etc/apt/sources.list (you need sudo)
comment out the lines that refer to the cdrom
then do a sudo apt update
The issue is you have told apt to look at the cd first. You want it to just go to the Debian repos.
- Routerworks
06 May 2023 12:46 #270792
by Routerworks
Replied by Routerworks on topic Secure (8) error Won't update
Thanks a lot for your advice. Not sure I fully understand. Apparently "apt-get update" automatically looks for the repositories on a CD rom? Honestly don't know how to comment out lines as you suggest. If you could offer some code that would be a big help, if not thanks anyway.
Regards
Regards
06 May 2023 12:53 #270793
Replied by Aciera on topic Secure (8) error Won't update
Maybe post the content of /etc/apt/sources.list so we can advise more clearly.
- Thank you received: 5944
06 May 2023 13:04 - 06 May 2023 13:06 #270794
Replied by tommylight on topic Secure (8) error Won't update
This is the second time i am reading about this error lately on this forum, this is the error you get if you do a copy from USB to hard drive using DD or some cloning software.
So the question is, how did you install it?
Are you the same one having the same issue twice?
To avoid this in the future, download ISO, use BalenaEtcher or any other utility to copy it properly to USB drive, boot the PC you want to install to from that USB, press enter at the grub menu-do not select any other option-whatever is selected leave it there, use the Installer from the Desktop or from the menu, follow installer-do not select stuff-leave default, reboot after finishing.
On first boot, first thing to do
sudo apt update
sudo apt upgrade
After this, install whatever you want, delete whatever, etc, etc.
sudo apt update
sudo apt upgrade
Last edit: 06 May 2023 13:06 by tommylight. Reason: typo/editor with breaks
- Routerworks
06 May 2023 13:40 #270795
by Routerworks
Thanks for your response. I have done some reading regarding rodw suggestion and think I can comment out the cd lines in source.list. If this doesn't work I have downloaded the ISO and have Balena for re-install. Think this is the first time I am asking this question.
Will let you know how it goes.
Thanks again.
Thanks again.
06 May 2023 15:24 #270799
Was hoping it was you, was going to ask what did you follow for the install procedure as this issue is not often asked, to avoid others from using it.
Now i have to keep monitoring ...
Thank you.
And feel free to report if you encounter the same or other issues.
Good and not good!Think this is the first time I am asking this question.
Thank you.
06 May 2023 21:11 #270818
router works. 2 ways to edit,
quick not friendly way
Nicer graphical more friendly way after installing geany text editor
To just dump the contents to the console to see what's in there
Me too. I think installing from a livecd is meant to remove the cd lines from sources.list on completion. Maybe it's not working.This is the second time i am reading about this error lately on this forum, this is the error you get if you do a copy from USB to hard drive using DD or some cloning software.
sudo nano /etc/apt/sources.list
sudo apt update
sudo apt install geany
sudo geany /etc/apt/sources.list
sudo cat /etc/apt/sources.list
- Routerworks
06 May 2023 21:49 #270823
by Routerworks
Update.
I was able to get into the sources.list and uncomment the cd lines as rodw suggested. It worked, was able to update and upgrade. Also was able to view sources.list with cat /etc....
This was a great learning curve for me. Gives you a real boost until the nest brick wall comes along. Speak of brick walls, I am trying to down load a wifi driver from github. When I use the recommended commands I get a "can't find it response".
It's a Tp-link ac600 which is probably the worst usb wifi adapter I could have purchased. Went through this some time ago and received more help than I should have but got it working on a different system. Learned a lot more in the meantime so I can understand if no one wants to bother with this.
However if I could understand why I can't git to work and can't download it as well that would be a big help. I was able to update and upgrade successfully.
Thanks again
Thanks again
- Routerworks
06 May 2023 21:56 #270824
by Routerworks
All else seems good. Apparently I don't have the "git" capability.
Time to create page: 0.165 seconds
