Help with homing
- Dimitrios2
08 May 2023 09:22 - 08 May 2023 09:35 #270910
by Dimitrios2
Help with homing was created by Dimitrios2
Hello,
I'm using linuxcnc 2.8.4 with Probe Basic and I'm new to linuxcnc. I have the following home sequence in the INI file below. My problem is that it's time I home my machine, my table is moving to Z-1, X-221 and Y-57 after the home switches are triggered as it should be but, is not setting the trigger points as 0. Actually the X and Y axis are a bit off, by 0.2mm and it's causing me troubles.
I do remember that yesterday the soft limit switches were working correctly. So, this is now. Did I mess up something?
Thanks in advance for your help.
[EMC]
MACHINE = Opti-mill
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = probe_basic
CONFIG_FILE = custom_config.yml
FULLSCREEN = True
OPEN_FILE = /home/jimmy/linuxcnc/nc_files/pb_examples/blank.ngc
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm 1in 2in 5in 10in
MAX_FEED_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.5
MAX_SPINDLE_OVERRIDE = 1.2
DEFAULT_LINEAR_VELOCITY = 2.30
MIN_LINEAR_VELOCITY = 0
MAX_LINEAR_VELOCITY = 23
INTRO_TIME = 0
PROGRAM_PREFIX = /home/jimmy/linuxcnc/nc_files
INCREMENTS = JOG 5mm 1mm .5mm .1mm .05mm .01mm .005mm
[KINS]
JOINTS = 3
KINEMATICS = trivkins coordinates=XYZ
[FILTER]
PROGRAM_EXTENSION = .nc,.tap G-Code File
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
SUBROUTINE_PATH = /home/jimmy/linuxcnc/configs/Opti-mill/subroutines/
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
BASE_PERIOD = 100000
SERVO_PERIOD = 1000000
[HAL]
HALUI = halui
HALFILE = Opti-mill.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
[TRAJ]
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
NO_FORCE_HOMING=1
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_X]
MAX_VELOCITY = 23
MAX_ACCELERATION = 50.0
MIN_LIMIT = 0.0
MAX_LIMIT = 436.0
[JOINT_0]
TYPE = LINEAR
MIN_LIMIT = 0.0
MAX_LIMIT = 436.0
MAX_VELOCITY = 23
#STEPGEN_MAXACCEL = 62.5
STEPGEN_MAXACCEL = 75
BACKLASH = 0.057
SCALE = 400.0
FERROR = 1
MIN_FERROR = .25
HOME = 221.0
HOME_OFFSET = 0.50
HOME_SEARCH_VEL = -8.00
HOME_LATCH_VEL = 0.50
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = -1
HOME_IS_SHARED = 1
HOME_USE_INDEX = NO
VOLATILE_HOME = 1
[AXIS_Y]
MAX_VELOCITY = 23
MIN_LIMIT = 0.0
MAX_LIMIT = 111.0
[JOINT_1]
TYPE = LINEAR
MIN_LIMIT = 0.0
MAX_LIMIT = 111.0
MAX_VELOCITY = 23
BACKLASH = 0.036
SCALE = 400.0
FERROR = 1
MIN_FERROR = .25
HOME = 57.0
HOME_OFFSET = 0.50
HOME_SEQUENCE = -1
HOME_IS_SHARED = 1
HOME_USE_INDEX = NO
VOLATILE_HOME = 1
[AXIS_Z]
MAX_VELOCITY = 23
MIN_LIMIT = -282.50
MAX_LIMIT = 0.0
[JOINT_2]
TYPE = LINEAR
MIN_LIMIT = -282.50
MAX_LIMIT = 0.0
MAX_VELOCITY = 23
BACKLASH = 0.021
SCALE = 400.0
FERROR = 1
MIN_FERROR = .25
HOME = -1.00
HOME_OFFSET = 0.50
HOME_SEARCH_VEL = 8.00
HOME_LATCH_VEL = -0.50
HOME_SEQUENCE = 0
HOME_IS_SHARED = 1
HOME_USE_INDEX = NO
VOLATILE_HOME = 1
[EMC]
MACHINE = Opti-mill
DEBUG = 0
VERSION = 1.1
[DISPLAY]
FULLSCREEN = True
EDITOR = gedit
ARCDIVISION = 64
INTRO_TIME = 0
[KINS]
JOINTS = 3
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
[HAL]
HALUI = halui
[TRAJ]
COORDINATES = X Y Z
LINEAR_UNITS = mm
NO_FORCE_HOMING=1
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
[AXIS_X]
MAX_VELOCITY = 23
MIN_LIMIT = 0.0
MAX_LIMIT = 436.0
[JOINT_0]
TYPE = LINEAR
MIN_LIMIT = 0.0
MAX_LIMIT = 436.0
MAX_VELOCITY = 23
BACKLASH = 0.057
SCALE = 400.0
FERROR = 1
MIN_FERROR = .25
HOME = 221.0
HOME_OFFSET = 0.50
HOME_SEQUENCE = -1
HOME_IS_SHARED = 1
HOME_USE_INDEX = NO
VOLATILE_HOME = 1
[AXIS_Y]
MAX_VELOCITY = 23
MIN_LIMIT = 0.0
MAX_LIMIT = 111.0
[JOINT_1]
TYPE = LINEAR
MIN_LIMIT = 0.0
MAX_LIMIT = 111.0
MAX_VELOCITY = 23
BACKLASH = 0.036
SCALE = 400.0
FERROR = 1
MIN_FERROR = .25
HOME = 57.0
HOME_OFFSET = 0.50
HOME_SEQUENCE = -1
HOME_IS_SHARED = 1
HOME_USE_INDEX = NO
VOLATILE_HOME = 1
[AXIS_Z]
MAX_VELOCITY = 23
MIN_LIMIT = -282.50
MAX_LIMIT = 0.0
[JOINT_2]
TYPE = LINEAR
MIN_LIMIT = -282.50
MAX_LIMIT = 0.0
MAX_VELOCITY = 23
BACKLASH = 0.021
SCALE = 400.0
FERROR = 1
MIN_FERROR = .25
HOME = -1.00
HOME_OFFSET = 0.50
HOME_SEQUENCE = 0
HOME_IS_SHARED = 1
HOME_USE_INDEX = NO
VOLATILE_HOME = 1
Last edit: 08 May 2023 09:35 by Dimitrios2.
08 May 2023 10:00 #270913
by JPL
This is possibly because you did not specify HOME_FINAL_VEL. Without this the last move is made at maximum velocity and probably overshoot the position. (see here: linuxcnc.org/docs/stable/html/config/ini...html#_home_final_vel)
Replied by JPL on topic Help with homing
... Actually the X and Y axis are a bit off, by 0.2mm and it's causing me troubles. ...
08 May 2023 10:12 #270914
by JPL
Is this what you want?
(Disclaimer: 5:00AM here, my brain may be slightly dysfunctional at this time)
I'm not sure I understand where you wan the 0 to be but I see that you have HOME_OFFSET = 0.50. This will set the 0 (home) to be 0.5mm away from the limit switches. If you want the 0 where the limit switches are triggered then HOME_OFFSET should be 0... my table is moving to Z-1, X-221 and Y-57 after the home switches are triggered as it should be but, is not setting the trigger points as 0
- Dimitrios2
08 May 2023 10:48 - 08 May 2023 11:11 #270918
by Dimitrios2
Replied by Dimitrios2 on topic Help with homing
Then why I'm able to pass the 0.5 without triggering the soft limit switches neither getting an error message to the end of travel? Isn't the home offset the end of travel after homing?
My home and hard limit switches are shared. I was expecting the table to be stopped before I hit the limit switches after homing.
P.S. Funny, I've tested by approaching slowly the switches and it worked. Now if I back off and go even faster it's working as expected. The machine is stopping where it should. I don't know, let me tested a bit more and I will come back if need it.
Last edit: 08 May 2023 11:11 by Dimitrios2.
- Dimitrios2
08 May 2023 11:14 #270919
by Dimitrios2
Sorry, I figure it out. My home switch was a bit loose.
The following user(s) said Thank You: joekline9
